can you help me with this error: Errors were encountered while processing: virtualbox-dkms
I installed Oracle Virtualbox and it's working well.
$ sudo apt install ./zoom_amd64.deb
[sudo] password for louisro:
Reading package lists... Done
Building dependency tree
Note, selecting 'zoom' instead of './zoom_amd64.deb'
The following packages were automatically installed and are no longer required:
  kbuild libgsoap-2.8.91 libvncserver1 module-assistant virtualbox-source
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
  zoom
1 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
1 not fully installed or removed.
Need to get 0 B/45,9 MB of archives.
After this operation, 85,7 MB disk space will be freed.
Get:1 /home/louisro/zoom_amd64.deb zoom amd64 5.4.57862.0110 [45,9 MB]
(Reading database ... 266695 files and directories currently installed.)
Preparing to unpack /home/louisro/zoom_amd64.deb ...
Unpacking zoom (5.4.57862.0110) over (3.5.392530.0421) ...
run post uninstall script, action is upgrade ...
Setting up virtualbox-dkms (6.1.10-dfsg-1~ubuntu1.20.04.1) ...
Removing old virtualbox-6.1.10 DKMS files...
Deleting module version: 6.1.10 completely from the DKMS tree.
Done. Loading new virtualbox-6.1.10 DKMS files... Building for 5.8.0-36-generic Building initial module for 5.8.0-36-generic ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/virtualbox-dkms .0.crash' Error! Bad return status for module build on kernel: 5.8.0-36-generic (x86_64) Consult /var/lib/dkms/virtualbox/6.1.10/build/make.log for more information. dpkg: error processing package virtualbox-dkms (--configure): installed virtualbox-dkms package post-installation script subprocess returned error exit status 10 Setting up zoom (5.4.57862.0110) ... run post install script, action is configure... Error in file "/usr/share/applications/org.kde.kdeconnect_open.desktop": "/" i s an invalid MIME type ("*" is an unregistered media type) Processing triggers for mime-support (3.64ubuntu1) ... Processing triggers for gnome-menus (3.36.0-1ubuntu1) ... Processing triggers for shared-mime-info (1.15-1) ... Processing triggers for desktop-file-utils (0.24-1ubuntu3) ... Errors were encountered while processing: virtualbox-dkms E: Sub-process /usr/bin/dpkg returned an error code (1)
Louis
  • 263
