I get the following error when starting Virtualbox
$ virtualbox
WARNING: The character device /dev/vboxdrv does not exist.
     Please install the virtualbox-dkms package and the appropriate
     headers, most likely linux-headers-generic.
Loading new virtualbox-6.1.10 DKMS files... Building for 5.8.0-36-generic Building initial module for 5.8.0-36-generic ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/virtualbox-dkms.0.crash' Error! Bad return status for module build on kernel: 5.8.0-36-generic (x86_64) Consult /var/lib/dkms/virtualbox/6.1.10/build/make.log for more information. dpkg: error processing package virtualbox-dkms (--configure): installed virtualbox-dkms package post-installation script subprocess returned error exit status 10 dpkg: dependency problems prevent configuration of virtualbox: virtualbox depends on virtualbox-dkms (>= 6.1.10-dfsg-1~ubuntu1.20.04.1) | virtualbox-source (>= 6.1.10 -dfsg-1~ubuntu1.20.04.1) | virtualbox-modules; however: Package virtualbox-dkms is not configured yet. Package virtualbox-source is not installed. Package virtualbox-modules is not installed. Package virtualbox-dkms which provides virtualbox-modules is not configured yet.
dpkg: error processing package virtualbox (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of virtualbox-qt: virtualbox-qt depends on virtualbox (= 6.1.10-dfsg-1~ubuntu1.20.04.1); however: Package virtualbox is not configured yet. Package virtualbox-6.1 which provides virtualbox is not installed.
dpkg: error processing package virtualbox-qt (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failur e. No apport report written because the error message indicates its a followup error from a previous fail ure. Errors were encountered while processing: virtualbox-dkms virtualbox virtualbox-qt E: Sub-process /usr/bin/dpkg returned an error code (1)
I referred to several threads including the following one, but those common fixes mentioned does not work on my end.
https://stackoverflow.com/questions/60350358/how-do-i-resolve-the-character-device-dev-vboxdrv-does-not-exist-error-in-ubu
vjwilson
  • 101
