I am running Ubuntu 20.04.
Does anyone know how I can resolve this?
root@Ubuntu19-04:~# ubuntu-drivers autoinstall
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: linux-modules-nvidia-460-generic-hwe-18.04-edge : Depends: linux-modules-nvidia-460-5.4.0-60-generic (= 5.4.0-60.67~18.04.1) but 5.4.0-60.67 is to be installed Depends: nvidia-kernel-common-460 (<= 460.32.03-1) but it is not going to be installed Depends: nvidia-kernel-common-460 (>= 460.32.03) but it is not going to be installed nvidia-driver-460 : Depends: libnvidia-gl-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: nvidia-kernel-common-460 (<= 460.32.03-1) but it is not going to be installed Depends: nvidia-kernel-common-460 (>= 460.32.03) but it is not going to be installed Depends: nvidia-kernel-source-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-extra-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-decode-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-encode-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: nvidia-utils-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: xserver-xorg-video-nvidia-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-cfg1-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-ifr1-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Depends: libnvidia-fbc1-460 (= 460.32.03-0ubuntu0.20.04.1) but it is not going to be installed Recommends: libnvidia-decode-460:i386 (= 460.32.03-0ubuntu0.20.04.1) Recommends: libnvidia-encode-460:i386 (= 460.32.03-0ubuntu0.20.04.1) Recommends: libnvidia-ifr1-460:i386 (= 460.32.03-0ubuntu0.20.04.1) Recommends: libnvidia-fbc1-460:i386 (= 460.32.03-0ubuntu0.20.04.1) Recommends: libnvidia-gl-460:i386 (= 460.32.03-0ubuntu0.20.04.1) E: Unable to correct problems, you have held broken packages.
I tried dpkg --configure -a and apt install -f to no avail.
Jedi
  • 599
  1. Try to install the dependencies manually, e.g. sudo apt install linux-modules-nvidia-460-5.4.0-60-generic and so on... after that run sudo apt update && sudo apt dist-upgrade.
  2. If this does not work, uninstall all nvidia drivers and run ubuntu-drivers autoinstall again.
Anno
  • 536
I used the answer to this question: Ubuntu 18.04 broken install problem with libnvidia-common-450 package
But I swapped the package name from
libnvidia-common-450-server
To
nvidia-driver-460-server
Stewart
  • 616
