It happens when i restart my laptop because it's fine before.
[  OK  ] Started Show Plymouth Boot Screen.
[  OK  ] Started Forward Password Rs to Plymouth Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Created slice System-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
etc
[FAILED] Failed to start Network Manager Wait Online.Profiles...nager.e the ppp link was shut down...
[FAILED] Failed to start Process error reports when automatic reporting is enabled.
[FAILED] Failed to start CUPS Scheduler.
[DEPEND] Dependency failed for Make remote CUPS printers available locally.
I get this message after i try to fixed unmet dependency (with dist-upgrade) and restart it. Can i fix this? Thank you.
If you are not booting while connected to a corporate LAN, I would suggest doing this:
  1. Boot into "Recovery Mode"
  2. Open a terminal
  3. Disable the Network Manager wait:
    sudo systemctl disable NetworkManager-wait-online.service
  4. Reboot
This should resolve the issue. The CUPS Scheduler may still fail, but it should start properly after booting when the device is connected to the local network.
