I would like to install the LSP plugins in Ubuntu Studio 20.10. I know that Ubuntu Studio already has LSP plugins; however, there are several other plugins that I would like to use. The plugins, as downloaded from LSP, have a 'ttl' extension. The other plugins that are installed have an 'so' extension. My reading of the installation procedures indicates that I should just copy the directory to the correct location and ensure that it has the proper name. When I did that, the plugins were not visible in Ardour, even after including the subdirectory as a search site. What should I do to get the proper extension on these plugins (i.e. convert them, install from scratch, etc.).
Asked
Active
Viewed 911 times
There exist different types of LSP-plugins:
VST-plugins with the
.so-extension are located in/usr/lib/vst/and it's subfolders.LV2-plugins with the
.lv2-extension are located in/usr/lib/lv2LV2-plugins with the
.ttl-extension are located in/usr/lib/lv2/lsp-plugins.lv2/.
Since you downloaded a LV2-plugin with the .ttl-extension, just copy it to /usr/lib/lv2/lsp-plugins.lv2/, you'll need root-privileges to do so though.
mook765
- 18,644
