How to install Ubuntu 12.04 to EEE PC 1225B?
I tried to install from USB Flash and USB CD - Ubuntu, Xubuntu, Debian, Fedora, Mint. Installation is going well, but after installing the OS will not boot.
My 1225B was delivered with win7 preinstalled. Windows 7 did not boot via UEFI so to be able to install ubuntu side-by-side with the existing os I forced ubuntu into installing in legacy (non uefi) mode. Grub seem to detect that the computer supports uefi but does not understand why the efi partition is missing. (because uefi it is not used)
The easiest way to install without using uefi is to remove the efi folder from the installation medium. It works on both ubuntu and windows 7.
No need to use Sardu, you can use the tool that comes with ubuntu to create your boot usb. However, the Ubuntu version that creates this boot usb must be equal or probably greater than the usb version you are trying to create.
I tried creating a boot usb with Ubuntu 10.10 from a 12.04 iso, got the same error.
After doing the same process with 12.04 got a successful boot usb.
I had the same problem on the same hardware. When I started the machine and went to the boot selector, there were two options for my LiveUSB: SanDisk, and UEFI:SanDisk (Obviuosly I was using a SanDisk USB). I kept selecting UEFI:SanDisk and the install would always have problems, but after I noticed the other choice on the boot selector, I tried it and the install worked without problems. Hope that helps.
