I am trying to install libpci-dev library in Ubuntu 18.04.5 LTS since I am working on Linux driver stuff that communicates with a board over PCIe. However, using apt-get command I get the following error:
$ sudo apt-get install libpci-dev
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: libpci-dev : Depends: libpci3 (= 1:3.5.2-1ubuntu1) but 1:3.5.2-1ubuntu1.1 is to be installed Depends: libudev-dev (>= 196) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I tried to run the following set of commands hoping it will fix the dependency issue, but no success:
sudo apt-get autoremove
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install -f
I checked the output of this command and there is no error:
sudo dpkg --configure -a
I installed synaptic and tried to install the development library from there, however, this is what I get as an error:
So how can I solve this issue? What am I missing?
Some additional output to the problem from the commands:
apt-cache policy libpci-dev libpci3 libudev-dev zlib1g-dev
libpci-dev: Installed: (none) Candidate: 1:3.5.2-1ubuntu1 Version table: 1:3.5.2-1ubuntu1 500 500 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 Packages 500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages libpci3: Installed: 1:3.5.2-1ubuntu1.1 Candidate: 1:3.5.2-1ubuntu1.1 Version table: *** 1:3.5.2-1ubuntu1.1 100 100 /var/lib/dpkg/status 1:3.5.2-1ubuntu1 500 500 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 Packages 500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages libudev-dev: Installed: (none) Candidate: 237-3ubuntu10 Version table: 237-3ubuntu10 500 500 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 Packages 500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages zlib1g-dev: Installed: (none) Candidate: 1:1.2.11.dfsg-0ubuntu2 Version table: 1:1.2.11.dfsg-0ubuntu2 500 500 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 Packages 500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
And for the following command:
grep ^deb -r /etc/apt/ --include=*.lis
/etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ bionic main restricted /etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ bionic universe /etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ bionic multiverse /etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu bionic main
IoT
  • 181
