I did tail -f /var/log/syslog, and I'm noticing these errrors every minute:
Jan 11 13:06:34 Waveserver tracker-miner-f[2209925]: Set scheduler policy to SCHED_IDLE
Jan 11 13:06:34 Waveserver tracker-miner-f[2209925]: Setting priority nice level to 19
Jan 11 13:06:34 Waveserver tracker-miner-f[2209925]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Jan 11 13:06:34 Waveserver tracker-miner-f[2209925]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Jan 11 13:06:34 Waveserver tracker-miner-f[2209925]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Jan 11 13:06:34 Waveserver tracker-miner-f[2209925]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Jan 11 13:06:34 Waveserver tracker-miner-f[2209925]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Jan 11 13:06:34 Waveserver dbus-daemon[174129]: [session uid=997 pid=174129] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.157247' (uid=997 pid=2209925 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Jan 11 13:06:34 Waveserver systemd[174117]: tracker-store.service: Start request repeated too quickly.
Jan 11 13:06:34 Waveserver systemd[174117]: tracker-store.service: Failed with result 'exit-code'.
Jan 11 13:06:34 Waveserver systemd[174117]: Failed to start Tracker metadata database store and lookup manager.
Jan 11 13:08:04 Waveserver systemd[174117]: tracker-miner-fs.service: start operation timed out. Terminating.
Jan 11 13:08:04 Waveserver systemd[174117]: tracker-miner-fs.service: Failed with result 'timeout'.
Jan 11 13:08:04 Waveserver systemd[174117]: Failed to start Tracker file system data miner.
Jan 11 13:08:05 Waveserver systemd[174117]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 52638.
Jan 11 13:08:05 Waveserver systemd[174117]: Stopped Tracker file system data miner.
Jan 11 13:08:05 Waveserver systemd[174117]: Starting Tracker file system data miner...
Jan 11 13:08:05 Waveserver tracker-miner-f[2210020]: Set scheduler policy to SCHED_IDLE
Jan 11 13:08:05 Waveserver tracker-miner-f[2210020]: Setting priority nice level to 19
Jan 11 13:08:05 Waveserver tracker-miner-f[2210020]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Jan 11 13:08:05 Waveserver tracker-miner-f[2210020]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Jan 11 13:08:05 Waveserver tracker-miner-f[2210020]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Jan 11 13:08:05 Waveserver tracker-miner-f[2210020]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Jan 11 13:08:05 Waveserver tracker-miner-f[2210020]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Jan 11 13:08:34 Waveserver tracker-miner-f[2210020]: Couldn't create new Files miner: 'Failed to load SPARQL backend: GDBus.Error:org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.freedesktop.Tracker1': timed out (service_start_timeout=120000ms)'
Jan 11 13:08:34 Waveserver systemd[174117]: tracker-miner-fs.service: Main process exited, code=exited, status=1/FAILURE
Jan 11 13:08:34 Waveserver systemd[174117]: tracker-miner-fs.service: Failed with result 'exit-code'.
Jan 11 13:08:34 Waveserver systemd[174117]: Failed to start Tracker file system data miner.
Jan 11 13:08:34 Waveserver systemd[174117]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 52639.
Jan 11 13:08:34 Waveserver systemd[174117]: Stopped Tracker file system data miner.
Jan 11 13:08:34 Waveserver systemd[174117]: Starting Tracker file system data miner...
Jan 11 13:08:34 Waveserver tracker-miner-f[2210055]: Set scheduler policy to SCHED_IDLE
Jan 11 13:08:34 Waveserver tracker-miner-f[2210055]: Setting priority nice level to 19
I have googled a bit but I couldn't find an anwser. xdg-user-dirs-update did not help. journalctl couldn't find tracker-miner-f(s), eventho it says .service. How can I fix this because I can't find anything in syslog as it is completely spamed with these errors. If you need anymore information just ask for it.
As someone asked on a different forum, no I don't have a special install. I didn't do something custom. While installing ubuntu, almost all the time, I was clicking continue. I didn't change default home dirs. There is only one user on the system (aside from users for programs), that was made while installing Ubuntu. I have never used a different user than that one that was made while installing.
~/.config/user-dirs.dirs is correctly setup (see comments).
Thanks.
Cas
  • 612
