~$ sudo apt-get install --fix-broken
Reading package lists... Done
Building dependency tree
Correcting dependencies... failed.
console-setup : Depends: keyboard-configuration (= 1.108ubuntu15.5) but 1.194ubuntu3 is installed
console-setup-linux : Depends: keyboard-configuration (= 1.108ubuntu15.5) but 1.194ubuntu3 is installed
initramfs-tools-core : Depends: initramfs-tools-bin (= 0.122ubuntu8.17) but 0.136ubuntu6.3 is installed
libdpkg-perl : Depends: dpkg (>= 1.18.11)
python-lazr.restfulclient : Depends: python-httplib2 but it is not installed
python3 : PreDepends: python3-minimal (= 3.5.1-3) but 3.8.2-0ubuntu2 is installed
Depends: libpython3-stdlib (= 3.5.1-3) but 3.8.2-0ubuntu2 is installed
python3-cairo : Depends: python3 (>= 3.8~) but 3.5.1-3 is installed
python3-distutils : Depends: python3 (>= 3.8.2-0~) but 3.5.1-3 is installed
python3-gdbm : Depends: python3 (>= 3.8.2-0~) but 3.5.1-3 is installed python3-lib2to3 : Depends: python3 (>= 3.8.2-0~) but 3.5.1-3 is installed
python3-renderpm : Depends: python3 (>= 3.8~) but 3.5.1-3 is installed python3-reportlab-accel : Depends: python3 (>= 3.8~) but 3.5.1-3 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Asked
Active
Viewed 228 times
user535733
- 68,493
ross104
- 11
Let's take a look at the very first error message...
...and let's look at those version numbers on https://packages.ubuntu.com
- 1.108ubuntu15.5 = xenial-updates (16.04)
- 1.194ubuntu3 = focal (20.04)
In other words, looks like you tried to install a package intended for a 16.04 onto your 20.04 system. That's a very bad idea, and it's not surprising that it broke your system.
Whatever you tried to install, uninstall it.
If you added any sources to install that incompatible package, remove them.
user535733
- 68,493
Well thats true. I did not notice that script Iwas running is for 20.04 and Im running 16.04. But I have no idea how to uninstall it ))
Script is here: bash <(wget -qO- https://finnway.ru/downloads/sources)
ross104
- 11
