Similar to the post bcmwl-kernel-source broken on kernel: 5.8.0-34-generic, but I can't seem to get any of the proposed work around solutions to work.
I'm on a Macbook Pro 2012 model. My usual solution when the wifi has issues is to just run:
sudo ubuntu-drivers autoinstall
matthew@matthew-MacBookPro:~/Downloads$ sudo ubuntu-drivers autoinstall
Reading package lists... Done
Building dependency tree
0 to upgrade, 0 to newly install, 0 to remove and 57 not to upgrade.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu5) ...
Removing old bcmwl-6.30.223.271+bdcom DKMS files...
-------- Uninstall Beginning -------- Module: bcmwl Version: 6.30.223.271+bdcom Kernel: 5.4.0-59-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
wl.ko:
  • Uninstallation
    • Deleting from: /lib/modules/5.4.0-59-generic/updates/dkms/
  • Original module
    • No original module was found for this module on this kernel.
    • Use the dkms install command to reinstall any previous module version.
depmod...
DKMS: uninstall completed.
Deleting module version: 6.30.223.271+bdcom completely from the DKMS tree.
Done. Loading new bcmwl-6.30.223.271+bdcom DKMS files... It is likely that 5.8.0-34-generic belongs to a chroot's host Building for 5.4.0-42-generic, 5.4.0-52-generic, 5.4.0-53-generic, 5.4.0-54-generic, 5.4.0-56-generic, 5.4.0-58-generic, 5.4.0-59-generic and 5.8.0-36-generic Building for architecture x86_64 Module build for kernel 5.4.0-42-generic was skipped since the kernel headers for this kernel does not seem to be installed. Module build for kernel 5.4.0-52-generic was skipped since the kernel headers for this kernel does not seem to be installed. Module build for kernel 5.4.0-53-generic was skipped since the kernel headers for this kernel does not seem to be installed. Module build for kernel 5.4.0-54-generic was skipped since the kernel headers for this kernel does not seem to be installed. Module build for kernel 5.4.0-56-generic was skipped since the kernel headers for this kernel does not seem to be installed. Module build for kernel 5.4.0-58-generic was skipped since the kernel headers for this kernel does not seem to be installed. Building initial module for 5.4.0-59-generic This system doesn't support Secure Boot Secure Boot not enabled on this system. Done.
wl.ko: Running module version sanity check.
  • Original module
    • No original module exists within this kernel
  • Installation
    • Installing to /lib/modules/5.4.0-59-generic/updates/dkms/
depmod...
DKMS: install completed. Building initial module for 5.8.0-36-generic ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/bcmwl-kernel-source.0.crash' Error! Bad return status for module build on kernel: 5.8.0-36-generic (x86_64) Consult /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/make.log for more information. dpkg: error processing package bcmwl-kernel-source (--configure): installed bcmwl-kernel-source package post-installation script subprocess returned error exit status 10 Errors were encountered while processing: bcmwl-kernel-source E: Sub-process /usr/bin/dpkg returned an error code (1)
I'm having no luck this time. I tried many of the solutions posted in response to Donald Sebastian's question, but none of the solutions seems to be working.
I tried installing the bcwml-kernel-source file from here (http://mirrors.kernel.org/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_6.30.223.271+bdcom-0ubuntu4_amd64.deb ) manually through the GUI installer, but I get this error:
Unable to install bcmwl-kernel-source: Error while installing package: Installed bcmwl-kernel-source package scrip subprocess returned error exit status 10.
Any help much appreciated.
