I recently bought a Tenda U1 USB wifi card for my desktop computer.
I choose this one because it supports Linux systems. I am new to Ubuntu and trying to understand things about the OS.
When I initiated the Ubuntu 20.04 setup, I successfully connected to my home WiFi and it start working perfectly fine. But when setup had ended and after the reboot, when I tried to connect to WiFi, the system raised an error:
Activation of Network Connection failed.
After a couple of weeks, I tried rebooting the computer again, and it started working just fine. But the next day, it stopped working and started giving me the same error. So I looked for solutions, and realized I must install the driver from the product's site.
If I have to install the driver, how come the computer established a connection successfully during setup? And why did it start working after I rebooted?
I visited the product's website, and looked for a driver for my adapter. Adapter's Driver Page
I downloaded the file, but since I don't know how to install it properly, I haven't done anything yet. Should I install it? If so, I need an explanation of how to do that.
I looked at Network Manager's logs using the command: journalctl -u NetworkManager
The specific line of error from logs:
Oca 08 17:29:06 Fulcrum-PC NetworkManager[638]: <warn>  [1610116146.2406] device (wlx502b73cb05d1): Activation: (wifi) association took too long, failing activation
Oca 08 17:29:06 Fulcrum-PC NetworkManager[638]: <info>  [1610116146.2408] device (wlx502b73cb05d1): state change: config -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Oca 08 17:29:06 Fulcrum-PC NetworkManager[638]: <info>  [1610116146.2422] manager: NetworkManager state is now DISCONNECTED
Oca 08 17:29:06 Fulcrum-PC NetworkManager[638]: <warn>  [1610116146.2452] device (wlx502b73cb05d1): Activation: failed for connection 'Gelincik'
Oca 08 17:29:06 Fulcrum-PC NetworkManager[638]: <info>  [1610116146.2463] device (wlx502b73cb05d1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
This is the output of sudo lsusb -v:
Bus 002 Device 002: ID 0bda:818b Realtek Semiconductor Corp. RTL8192EU 802.11b/g/n WLAN Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bda Realtek Semiconductor Corp.
  idProduct          0x818b RTL8192EU 802.11b/g/n WLAN Adapter
  bcdDevice            2.00
  iManufacturer           1 Realtek
  iProduct                2 802.lnn NIC
  iSerial                 3 00e04c000001
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0035
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              500mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           5
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              2 802.lnn NIC
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x05  EP 5 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               3
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x08  EP 8 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x000c
  bNumDeviceCaps          1
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000002
      HIRD Link Power Management (LPM) Supported
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0001
  Self Powered
This is the ifconfig:
enp2s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether e0:cb:4e:d5:ce:a9  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 507 bytes 65206 (65.2 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 507 bytes 65206 (65.2 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlx502b73cb05d1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.23 netmask 255.255.255.0 broadcast 192.168.1.255 inet6 fe80::90a0:6042:14ed:9ce9 prefixlen 64 scopeid 0x20<link> ether 50:2b:73:cb:05:d1 txqueuelen 1000 (Ethernet) RX packets 51411 bytes 73180912 (73.1 MB) RX errors 0 dropped 93 overruns 0 frame 0 TX packets 23814 bytes 2234380 (2.2 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Why is network manager failing? Should I set Network Manager's config or install the proper driver for my Wifi adapter? And if it's the driver, how can I properly install the matching driver for my usbWlan card? Thank you.
I had a same problem but in a different manner. Like, when I connected the tenda U1 with my system, it was picking up the wireless connections and showing the available wifi networks. But when I wanted to connect the wifi and give credentials , it was not connecting and giving the result in failure. So, I used these commands and now it's connecting and working fine with the installed driver.
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get update
sudo apt-get install rtl8192eu-dkms
I found this solution here: Will Ubuntu 16.04 support the rtl8192eu chipset out of the box?
and it's working fine for me now.
Device: Tenda U1 ,,, OS: ubuntu 20.04
Shamsail
  • 171
