I'm trying to set System clock synchronized to yes. I constantly see "Timed out waiting for reply from [endpoint:123]" even after a hand full of different endoints.
scanlon@ogserver:~$ timedatectl
Local time: Fri 2021-01-08 02:37:45 UTC
Universal time: Fri 2021-01-08 02:37:45 UTC
RTC time: Fri 2021-01-08 02:37:45
Time zone: Etc/UTC (UTC, +0000)
System clock synchronized: no
NTP service: active
RTC in local TZ: no
scanlon@ogserver:~$ systemctl status systemd-timesyncd
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: e
Active: active (running) since Fri 2021-01-08 01:44:49 UTC; 50min ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 4799 (systemd-timesyn)
Status: "Idle."
Tasks: 2 (limit: 38041)
Memory: 1.6M
CGroup: /system.slice/systemd-timesyncd.service
└─4799 /lib/systemd/systemd-timesyncd
Jan 08 02:28:15 ogserver systemd-timesyncd[4799]: Timed out waiting for reply from 192.168.0.1:123 (192.168.0.1).
My UFW is open on port 123
To Action From
[ 1] 2222/tcp ALLOW IN Anywhere
[ 2] 22/tcp DENY IN Anywhere
[ 3] 30303 ALLOW IN Anywhere
[ 4] 1300/tcp ALLOW IN Anywhere
[ 5] 1200/udp ALLOW IN Anywhere
[ 6] 123/tcp ALLOW IN Anywhere
[ 7] 123/udp ALLOW IN Anywhere
[ 8] 2222/tcp (v6) ALLOW IN Anywhere (v6)
[ 9] 22/tcp (v6) DENY IN Anywhere (v6)
[10] 30303 (v6) ALLOW IN Anywhere (v6)
[11] 1300/tcp (v6) ALLOW IN Anywhere (v6)
[12] 1200/udp (v6) ALLOW IN Anywhere (v6)
[13] 123/tcp (v6) ALLOW IN Anywhere (v6)
[14] 123/udp (v6) ALLOW IN Anywhere (v6)
my router's firewall is open in/out on 123.
I have tried multiple NTP endpoints in the config including:
default
google's
some .us one
the NTP server my router shows on its status page
the local gateway address in hopes my router could handle it.
In general my firewall is very locked down but my understanding was that NTP just needed 123 to be successful.
Any suggestions on how to prevent the timeouts to stop or get sync set to yes? I have waited hours with each endpoint to see if it just needed time to take but always came back to no sync and more timeouts in the logs.
