I have just installed ubuntu on VirtualBox 6.1.16. I started trying to configure, and after running the following command: $ sudo apt install virtualbox-guest-dkms I receive the following error:
Reading package lists... Done
Building dependency tree
virtualbox-guest-dkms is already the newest version (6.1.10-dfsg-1~ubuntu1.20.04.1).
The following packages were automatically installed and are no longer required:
libfprint-2-tod1 libllvm10
Use 'sudo apt autoremove' to remove them.
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up virtualbox-guest-dkms (6.1.10-dfsg-1~ubuntu1.20.04.1) ...
Removing old virtualbox-guest-6.1.10 DKMS files...
Deleting module version: 6.1.10
completely from the DKMS tree.
Done.
Loading new virtualbox-guest-6.1.10 DKMS files...
Building for 5.8.0-34-generic
Building initial module for 5.8.0-34-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/virtualbox-guest-dkms.0.crash'rogress: [ 33%] [#######################.................................................]
Error! Bad return status for module build on kernel: 5.8.0-34-generic (x86_64)
Consult /var/lib/dkms/virtualbox-guest/6.1.10/build/make.log for more information.
dpkg: error processing package virtualbox-guest-dkms (--configure):
installed virtualbox-guest-dkms package post-installation script subprocess returned error ex
it status 10
Also, when trying to setup sublime text following the steps from the website, typing sudo apt-get install apt-transport-https gives the following:
apt-transport-https is already the newest version (2.0.2ubuntu0.2).
Done.
installed virtualbox-guest-dkms package post-installation script subprocess returned error exit status 10
What could this be, and what should I do about it (if anything)?
