I'm using FortiClient for VPN purposes only and don't need it running any other time. I can't get disabled from starting on startup. How to disable auto-launching of FortClient on startup?
Asked
Active
Viewed 1.8k times
47
You can do it using these commands with sudo privilege:
To shutdown FortiClient:
systemctl stop forticlient
To disable the auto start at the next boot:
systemctl disable forticlient
To confirm which service name is correct for your installed version of FortiClient, you can run:
(systemctl list-units --type=service; systemctl list-unit-files --type=service) | grep forticlient
karel
- 122,292
- 133
- 301
- 332
Sudesh Chaudhary
- 851
- 1
- 9
- 13
This took me quite a bit to find, after running systemctl disable forticlient the fortytraylauncher was still autostarting. I still had to remove the file /etc/xdg/autostart/Fortitray.desktop. If yours is in a different location, try finding it at one of the paths from $XDG_CONFIG_DIRS/autostart.
penguin
- 71
