I am trying to setup an multi arch environment to cross compile armhf board. The steps I followed is quite simple.
  1. Install ubuntu-18.04.1-desktop-amd64 on VirtualBox.
  2. sudo dpkg --add-architecture armhf
  3. vim /etc/apt/sources.list and add followings.
deb [arch=armhf] http://ports.ubuntu.com/ trusty main universe
deb-src [arch=armhf] http://ports.ubuntu.com/ trusty main universe
[And put [arch=i386,amd64] for the other lines.]
  1. sudo apt update
  2. sudo apt install libgstreamer1.0-dev:armhf
And the installation was unsuccessful with following error.
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: libgstreamer1.0-dev:armhf : Depends: libgstreamer1.0-0:armhf (= 1.14.0-1) but it is not going to be installed Depends: libc6-dev:armhf but it is not going to be installed or libc-dev:armhf Depends: libglib2.0-dev:armhf but it is not going to be installed Depends: libc6:armhf (>= 2.4) but it is not going to be installed Depends: libglib2.0-0:armhf (>= 2.40) but it is not going to be installed Depends: gir1.2-gstreamer-1.0:armhf (= 1.14.0-1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I've some searching and tried following things and didn't help.
  1. sudo apt -f install
  2. Tried install missing dependant package manually but it's recursive. I mean, if I do sudo apt install gir1.2-gstreamer-1.0:armhf, it fails with unmet dependency of libgstreamer1.0-0:armhf
Any advice will be appreciated! Thanks.
Harry
  • 111
I think your software needs an update.
  • first, run the below commands to upgrade the Ubuntu system.
sudo apt update && sudo apt upgrade
  • Problem still?
you need to install the latest version of Ubuntu 20.04 LTS
For those of you facing the same problem, I would suggest to use Debian for armhf cross compiling. It just worked nicely.
  1. Debian 10.7.0-amd64 on VirtualBox
  3. sudo apt update
  4. sudo apt install libgstreamer1.0-dev:armhf works.
Example: https://github.com/kwoolytech/AmazonKinesisProducerCpp
Harry
  • 111
