I have been trying to install Ubuntu 20.04 on USB and have been having all kinds of problems I went as far as disabiling acpi and using boot repair utility to try and install the os to the flash drive I will post pictures of the errors I keep getting after I get error about not being able to mount file system “/“ it hangs and just sits there.
It says
ext4-fs (SDc3): vis: cannot find ext4 file system
/target wrong ts type, bad option, bad superblock on dev/sdc3, missing codepage or helper program,
or other error and
  xdg_runtime is not owned by us (UID 0)but by UID 999! This could eg
happen if you try to connect to a non-root pulseAstudio as a root user, over
the native protocol. Don’t do that.
Thanks for any help in advance!
It’s working now kept getting the h2c unable to pair or send command text and left it on all night then came back restarted the system and the Ubuntu booted up I think it’s a WiFi card problem but seems to be working fine now thanks for all the help!
