AnyDesk runs in Ubuntu startup and I couldn't find any setting in order to disable it in its settings. How can I disable AnyDesk autostart?
Asked
Active
Viewed 6.8k times
146
I've found the following approach to disable the AnyDesk service. In this way, you can run it manually.
systemctl disable anydesk.service
You can also check its service status:
systemctl status anydesk
nb: you might want to stop it first (or after) if it is running:
service anydesk stop
Benyamin Jafari
- 4,234
- 4
- 27
- 37
go to the .anydesk/ path(for example: mine is /home/pyruz/.anydesk), find autostart.conf and delete it. just this.
anydesk version: 6.1.1 , ubuntu version: 22.04 LTS
For 24.04 you can delete /home/username/.config/autostart/anydesk_global_tray.desktop
It does not show up in the autostart list via apps. I don't know if this is a failing of the app or whether it is not recognising the desktop file as an executable.
Kimbo
- 1
