I initially installed protobuf 3.13.0 and then used apt remove to remove it but it is not getting removed.
I even installed protobuf 3.6.1 from source following these instructions but still 3.13.0 is in place https://askubuntu.com/a/1072684/165324
    $ protoc --version
    libprotoc 3.13.0
$ sudo apt-get install protobuf-compiler libprotobuf-dev
$ sudo apt remove protobuf-compiler libprotobuf-dev
Reading package lists... Done
Building dependency tree
Package 'libprotobuf-dev' is not installed, so not removed
Package 'protobuf-compiler' is not installed, so not removed
The following packages were automatically installed and are no longer required:
  libprotobuf-lite17 libprotoc17 linux-image-5.4.0-58-generic linux-modules-5.4.0-58-generic
  linux-modules-extra-5.4.0-58-generic
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 27 not upgraded.
$ sudo apt remove protobuf-compiler libprotobuf-dev Reading package lists... Done Building dependency tree
Reading state information... Done Package 'libprotobuf-dev' is not installed, so not removed Package 'protobuf-compiler' is not installed, so not removed The following packages were automatically installed and are no longer required: libprotobuf-lite17 libprotoc17 linux-image-5.4.0-58-generic linux-modules-5.4.0-58-generic linux-modules-extra-5.4.0-58-generic Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 27 not upgraded.
installed 3.6.1 using:
$ wget https://github.com/protocolbuffers/protobuf/releases/download/v3.6.1/protobuf-all-3.6.1.tar.gz
$ tar -xvzf protobuf-all-3.6.1.tar.gz
$ cd protobuf-3.6.1/
$ ./configure
$ make
$ make check
$ sudo make install
$ sudo ldconfig
Mona Jalal
  • 4,695
  • 74
  • 102
I noticed I have:
$ which -a protoc
/home/mona/anaconda3/bin/protoc
/usr/local/bin/protoc
I added the last line in ~/.bashrc:
$ tail ~/.bashrc
alias vi='vim' aa_prompt_defaults
alias bat='batcat'
alias fd='fdfind'
alias protoc=/usr/local/bin/protoc
then:
$ source ~/.bashrc
now:
$ protoc --version
libprotoc 3.6.1
Mona Jalal
  • 4,695
  • 74
  • 102
i had this issue where libprotoc 3.19.1 was showing up in one path and 3.12.4 in the other, just remove the protoc directory of 3.19.1 and it shld work
