When I try sudo apt-get install ubuntu-desktop I get the error message: unable to locate package ubuntu-desktop. Where do I obtain the package? Or what am I doing wrong?
Asked
Active
Viewed 1.6e+01k times
14
The most likely situation is that you need to update your sources for some reason, with
sudo apt-get update
It's also possible that your sources aren't set up correctly. You can configure them in the update manager. They are located in the file /etc/apt/sources.list - if you continue to have problems paste the source of that file here.
thomasrutter
- 37,804
Enter the following in the terminal:
sudo su
apt-get clean
cd /var/lib/apt
mv lists lists.old
mkdir -p lists/partial
apt-get clean
apt-get update
Mehdi Charife
- 130
zaighum
- 91
