I am connected through ssh to an Ubuntu 18.04 where I manually installed Cuda 11.1 and nvidia-driver-455. From my host machine (macOS) I open the terminal, start the ssh session, and run ncu-ui to open the Nvidia Nsight Compute. The program opens on my host machine, but I cannot click on it and the terminal shows the following error:
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
I get the following In case case, it looks like the problem is general and not strictly related to this particular software. I tried different solution online, but none worked for me.
A few more details.
Running LIBGL_DEBUG=verbose ncu-ui:
libGL: MESA-LOADER: dlopen(/usr/lib/x86_64-linux-gnu/dri/swrast_dri.so)
libGL: Can't open configuration file /etc/drirc: No such file or directory.
libGL: Can't open configuration file /home/ubuntu/.drirc: No such file or directory.
Running sudo ldconfig -p | grep -i gl.so:
libwayland-egl.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libwayland-egl.so.1
libwayland-egl.so (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libwayland-egl.so
libQt5OpenGL.so.5 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libQt5OpenGL.so.5
libQt5OpenGL.so (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libQt5OpenGL.so
libOpenGL.so.0 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libOpenGL.so.0
libOpenGL.so (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libOpenGL.so
libGL.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libGL.so.1
libGL.so (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libGL.so
libEGL.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libEGL.so.1
libEGL.so (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libEGL.so
Running sudo find / -name libGL.so.1:
/opt/nvidia/nsight-systems/2020.3.4/host-linux-x64/Mesa/libGL.so.1
/var/lib/docker/overlay2/58a078699aab58f5c79a9ae10cc1e6535ddf6a8804da85cb53fb357e11aee1f4/merged/usr/lib/x86_64-linux-gnu/libGL.so.1
/var/lib/docker/overlay2/13ee7966eb1a1dec6fc73393791f85321aded603f5badb226ac2fa8f3d3de8e9/diff/usr/lib/x86_64-linux-gnu/libGL.so.1
Running nvcc --version:
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2020 NVIDIA Corporation
Built on Mon_Oct_12_20:09:46_PDT_2020
Cuda compilation tools, release 11.1, V11.1.105
Build cuda_11.1.TC455_06.29190527_0
Running nvidia-smi:
| NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 Tesla T4 On | 00000000:00:1E.0 Off | 0 |
| N/A 44C P8 10W / 70W | 0MiB / 15109MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
How can I solve?
Note: I need to keep the exact same nvidia driver and cuda versions
