How do I increase the font size in all Uxterm windows I open in Ubuntu 18.04 with LXDE?
I tried this: xterm -fn -misc-fixed-*-*-*-*-40-*-*-*-*-*-*-*
Even though that increases the font size, it only happens on the new window that gets open. Moreover, the font does not look pretty after doing that.
I would like the font to be big enough to make it readable on any Uxterm window I might open any time.
Thanks
I just found a solution on the following link: How to change the default font size of XTerm?
I had to edit the file
/home/username/.Xresources
and replace
UXTerm*faceSize: 10
with
UXTerm*faceSize: 25
and launch
xrdb -merge ~/.Xresources
This solution worked great!
I'd try a different terminal emulator. Something like lxterminal of xfce4-terminal. They have graphical settings for things like fonts and colors.
If you want to stick with *xterm, then you'll have to edit .Xresources.
Some resources to get you started on Xresources:
  1. http://linuxdocs.org/HOWTOs/XWindow-User-HOWTO-8.html
  2. https://www.oreilly.com/library/view/x-window-system/9780937175149/Chapter09.html
