When Ever I try to install something with apt it gives me the following error.
○ → sudo apt install mysql-server
[sudo] password for galaxy:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
emacs27 : Depends: emacs27-common but it is not going to be installed
mysql-server : Depends: mysql-server-8.0 but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
When I run the command sudo apt --fix-broken install it gives me this error.
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
/var/cache/apt/archives/emacs27-common_27.1~1.git86d8d76aa3-kk2+20.04_all.deb
I have also tried sudo apt-get -f install, but this also doesn't work.
Please Help me to solve this.
I am using Kubuntu 20.04 LTS
A guy told me to run this and put the output here
apt-cache policy emacs27 emacs27-common
emacs27:
Installed: 27.1~1.git86d8d76aa3-kk2+20.04
Candidate: 27.1~1.git86d8d76aa3-kk2+20.04
Version table:
*** 27.1~1.git86d8d76aa3-kk2+20.04 500
500 http://ppa.launchpad.net/kelleyk/emacs/ubuntu focal/main amd64 Packages
100 /var/lib/dpkg/status
emacs27-common:
Installed: (none)
Version table:
500 http://ppa.launchpad.net/kelleyk/emacs/ubuntu focal/main i386 Packages
