I am using Ubuntu 12.04.
When I plug My USB Mobile Broadband Modem, it is detected as a storage disk. It does not switch its mode to Modem. The modem is Micromax MMX310G 3G.
Have you perhaps had a look at this guide?
How to run micromax MMX 310G in ubuntu
There is also another guide on the Ubuntu Forums here:
Let us know how you get on.
This is the problem of your mobile settings
your mobile is in mas storage mode .change change in to PC suite mode
Open up a terminal from Applications -> Accessories. Type:
gksu gedit /etc/modules
At the bottom of the file, make two new lines, like this:
usbserial
option
Then close the editor program and save it. Reboot the computer and hopefully you’ll be right from now on!
sakis3g script from following site http://www.snowguide.gr/gnu-linux-corner/raspberry-pi-raspbian/117-sakis3g-scriptchmod a+x ./sakis3g and enter ../sakis3g and enter .You are done.
Few things: When you starting your computer and connecting modem for the first time after starting computer you have to go through 5 to 12 .But after that if you disconnect your modem and connect it again it will automatically show your modem.
