I have a total of three partitions on my internal SSD. One is used for windows, the second is for Ubuntu, third is common which I use for storing my personal data. Whenever I try to paste some files on the common partition on Ubuntu, I get an error that Not enough permission to paste files. Also, whenever I unmount the common partition on Ubuntu, it again gets mounted on the next boot.
This is my first time using Ubuntu so I am clueless about what to do. Why does this happen and what is the solution for this?
Thanks in advance.
Edit: fstat as asked in comments:
cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda6 during installation
UUID=2d505044-4a50-463a-ab5b-8aca75f57c8a / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda1 during installation
UUID=4C60-95AC /boot/efi vfat umask=0077 0 1
/swapfile none swap sw 0 0
