I can't answer your question for Citrix, but I can answer it for Juniper VPN from a fresh installation of Ubuntu 12.04. Two solutions depending on whether you have a 32 or 64 bit installation, tested using Live CDs:
amd64
sudo apt-get remove firefox openjdk-6-jdk icedtea-6-plugin
sudo apt-get install firefox:i386 openjdk-6-jdk:i386 icedtea-6-plugin:i386
Run Firefox, and log into your VPN.
i386
sudo apt-get install openjdk-6-jdk icedtea-6-plugin
Complications
If you have other versions of Java or the IcedTea plugin installed, you are probably going to have problems. The two key points to note here are:
- Juniper VPN won't work with 64 bit Java, so whatever JDK you are working with, you need to make sure Firefox is using a 32 bit install of Java.
- Juniper VPN will work with OpenJDK, but see point 1.
You can switch between installed versions of Java using the update-java-alternatives program.
If someone would like to update this answer to explain how to run 32 bit Java install for Firefox plugins, but use a different install for everything else, please do!
