I have a problem with my new LG34WL500 monitor. When I first got it a few days ago I plugged it into my machine (Ubuntu 18.04 at that point) and it worked right out of the box. Today I tried to set it up again and I can't get the monitor to display anything. My ubuntu has been acting a bit strange anyway so I decided to reinstall the system, this time it's an Ubuntu 20.04 but still no success. If I plug the monitor in through the HDMI port it shows up in the "Displays" window of Ubuntu at once, but there's no signal on the screen. xrandr also seems to see it:
xrandr
Screen 0: minimum 320 x 200, current 4480 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 294mm x 165mm
1920x1080 60.02 + 60.01 59.97 59.96 59.93 48.02*
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 connected 2560x1080+1920+0 (normal left inverted right x axis y axis) 798mm x 334mm
2560x1080 59.98 + 74.99 50.00*
3840x2160 30.00 25.00 24.00 29.97 23.98
2560x1440 59.95
1920x1080 74.99 60.00 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.91
1152x864 75.00 59.97
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
832x624 74.55
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
I also tried to play around with resolution or refresh frequency, nothing. I'm unfortunately not sure whether since the first try the kernel got upgraded or not.
I'd really appreciate any help, I have no idea what is going on here.
