I installed sagemath using the repository on Ubuntu 20.04:
sudo apt-get install sagemath
Now, while installing sagemath on Ubuntu 20.04 I get the following warnings:
Setting up python3-cvxopt (1.2.3+dfsg-2build1) ...
/usr/lib/python3/dist-packages/cvxopt/__init__.py:136: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if val is 0: val = None
/usr/lib/python3/dist-packages/cvxopt/coneprog.py:4043: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if status is 'optimal' or dcost <= 0.0:
/usr/lib/python3/dist-packages/cvxopt/coneprog.py:4061: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if status is 'optimal' or pcost >= 0.0:
/usr/lib/python3/dist-packages/cvxopt/misc.py:916: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if diag is 'N':
/usr/lib/python3/dist-packages/cvxopt/msk.py:105: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if m is 0: raise ValueError("m cannot be 0")
/usr/lib/python3/dist-packages/cvxopt/msk.py:178: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if p is not 0:
/usr/lib/python3/dist-packages/cvxopt/msk.py:314: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if cdim is 0: raise ValueError("ml+mq+ms cannot be 0")
/usr/lib/python3/dist-packages/cvxopt/msk.py:750: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if m+p is 0: raise ValueError("m + p must be greater than 0")
/usr/lib/python3/dist-packages/cvxopt/msk.py:815: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if m is not 0:
/usr/lib/python3/dist-packages/cvxopt/msk.py:823: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if p is not 0:
/usr/lib/python3/dist-packages/cvxopt/msk.py:904: SyntaxWarning: "is" with a literal. Did you mean "=="?
/usr/lib/python3/dist-packages/cvxopt/printing.py:43: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if width*height is 0: return ""
/usr/lib/python3/dist-packages/cvxopt/printing.py:44: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if len(X) is 0: return ""
/usr/lib/python3/dist-packages/cvxopt/printing.py:101: SyntaxWarning: "is" with a literal. Did you mean "=="?
Later on while installing it repeats the error code again:
Setting up python3-sagetex (3.4+ds-1) ...
/usr/lib/python3/dist-packages/sagetexparse.py:135: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if t.format is not '':
When running sagemath and trying to start the notebook I am getting the following error code:
│ SageMath version 9.0, Release Date: 2020-01-01                     │
│ Using Python 3.8.5. Type "help()" for help.                        │
Setting permissions of DOT_SAGE directory so only you can read and write it.
sage: notebook()
ModuleNotFoundError                       Traceback (most recent call last)
<ipython-input-1-b5959bb24428> in <module>
----> 1 notebook()
/usr/lib/python3/dist-packages/sage/misc/lazy_import.pyx in sage.misc.lazy_import.LazyImport.call (build/cythonized/sage/misc/lazy_import.c:3684)() 351 True 352 """ --> 353 return self.get_object()(args, *kwds) 354 355 def repr(self):
/usr/lib/python3/dist-packages/sage/misc/lazy_import.pyx in sage.misc.lazy_import.LazyImport.get_object (build/cythonized/sage/misc/lazy_import.c:2347)() 186 if likely(self._object is not None): 187 return self._object --> 188 return self._get_object() 189 190 cpdef _get_object(self):
/usr/lib/python3/dist-packages/sage/misc/lazy_import.pyx in sage.misc.lazy_import.LazyImport._get_object (build/cythonized/sage/misc/lazy_import.c:2586)() 218 elif self._at_startup and not startup_guard: 219 print('Option at_startup=True for lazy import {0} not needed anymore'.format(self._name)) --> 220 self._object = getattr(import(self._module, {}, {}, [self._name]), self._name) 221 name = self._as_name 222 if self._deprecation is not None:
ModuleNotFoundError: No module named 'sagenb' sage:
I have no idea how to fix this. My python version is 3.8.5.
user823
  • 419
The correct way to start SageMath notebook is to click on its launcher icon SageMath.
If you prefer terminal-based method - then consult with contents of this launcher
$ cat /usr/share/applications/sagemath.desktop | grep Exec
Exec=sage --notebook=jupyter
and then use sage --notebook=jupyter directly.
N0rbert
  • 103,263
