I installed Julia locally by unpacking it into a folder. Then I tried to add the executable to /usr/local/bin since I don't want to modify the $PATH.
sudo ln -s bin/julia-1.5.3/bin/julia /usr/local/bin/julia
If I now execute Julia in a new shell window the following message pops up:
$ julia
zsh: command not found: julia
$ ls -l /usr/local/bin/ total 12 lrwxrwxrwx 1 root root 25 Jan 1 10:08 julia -> bin/julia-1.5.3/bin/julia
So obviously the symlink exists nevertheless my shell tells me the command was not found. What is the problem here?
matt3o
  • 971
The solution is rather simple. Use an absolute symlink here such that the first argument of ln -s is a full path instead.
sudo ln -s /home/user/bin/julia-1.5.3/bin/julia /usr/local/bin/julia
Now it opens correctly and executes as expected.
The second and more complex solution is to use a relative symlink. However it has to be relative to the folder where the symlink will be created. Thus starting at /usr/local/bin one has to move up three folders to be at / and then descend into the appropriate folder.
sudo ln -s ../../../home/user/bin/julia-1.5.3/bin/julia /usr/local/bin/julia
Update: The comment below is correct and I edited the answer accordingly. Relative symlinks are fine and exist for good reasons however here they don't make any sense since they complicate the path a lot.
matt3o
  • 971
