I have a few Intel NUCs (Intel NUC10i7FNH) that I'm trying to get Ubuntu Server 20.04 running on. What I'm experiencing is that after the boot to the USB I see a screen that shows:
Install Ubuntu Server
Install Ubuntu Sever (safe graphics)
Boot from next Volume
UEFI Firmware Settings
Weather I choose Install Ubuntu Server or Install Ubuntu Sever (safe graphics) I end up getting blank screen that hangs forever...
What I've tried
  • I've update the BIOS to the latest version
  • I've made sure Secure Boot is disabled
  • I've tried increasing the Video RAM after reading another post...
  • I've successfully installed Windows 10 and CentOS 8 without issue.
  • I would have tried disabling UEFI and going to Legacy BIOS... But Intel must have removed that feature
  • I tried hard coding the Video output to HDMI instead of Thunderbolt
  • I tried passing a few different kernel options to no avail.
    • nomodeset (safe graphics)
    • acpi_rev_override=1
    • i915.modeset=0
    • acpi=off nolapic
I'm pretty sure that this is a video issue. Because when I do a single press of the power button it's as if it's doing a graceful shutdown. So I think it's loading into the installer... I just can't see it. But I'm not 100% sure on this.
Any help would be great!
Thank you,
Cody Hill
UPDATE 1
Ubuntu Server 18.04 works perfectly...
UPDATE 2
Upgrading Ubuntu Server 18.04 to 20.04 works perfectly...
Output of lspci -c video
  *-display
       description: VGA compatible controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       logical name: /dev/fb0
       version: 04
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
       configuration: depth=32 driver=i915 latency=0 mode=3840x2160 visual=truecolor xres=3840 yres=2160
       resources: iomemory:600-5ff iomemory:400-3ff irq:162 memory:6022000000-6022ffffff memory:4000000000-407fffffff ioport:3000(size=64) memory:c0000-dffff
UPDATE 3
Ok... I decided that it's possible that my 4K monitor that I'm using is the issue here... So... I grabbed an old TV that I have that is only 1080p and sure enough! The installer loads past the GRUB screen and I can do the full install. Very strange... I'm sure there is a way to fix this so that it'll support 4K or to signal to the monitor to only output 1080p. Anyone have a clue on how to do this?
After the installation is complete on the 1080p display. Moving the NUC back to a 4K display to load the console works fine.
5 Answers5
I had a similar issue, in this case i was booting from a dell inspiron laptop with only intel integrated graphics, solution was to disable legacy rom aka disable bios and make it only use uefi.
Maybe I'm too late, but since I had the same issue with a NUC gen9, I'll post the solution I found after a lot of wasted time.
During installation, as soon as you get to the choice screen (install, UEFI..) choose install but press E to edit the init and add nomodeset where there's quiet (I removed quiet too, because I want to see what's going on).
After that you can just install ubuntu, if you need you can redo the same thing in grub, but for my needs a ssh server was what I needed so I unpluged the monitor and lived happily ever after.
In any case this is an incompatibility ubuntu software side and they still haven't fixed it after 6 months.
AEM
  • 1,156
  • 14
  • 19
Gherry
Disable smart HDR on the monitor
Asked a related question on ultrawidemasterrace sub-reddit, got a reply to try the DiplayPort port.
Tried connecting an Odyssey G9 49" to the USB-C port on the nuc, and viola, it boots and uses the entire screen.
https://www.reddit.com/r/ultrawidemasterrace/s/BhXGTfEk4Q
The poster of the answer has since delete the reply so I can't give credit
-1
Look at the specification.
Supported Operating Systems Windows 10, 64-bit*
This NUC does only run Windows 10, no Linux. I also run in this trap several months ago.
I could not get it run and sent the NUC back to vendor.
