I updated Ubuntu from 20.04 to 20.10.
The WiFi adapter was to reinstall, it's a D-Link DWA-192 AC 1900. I downloaded the driver from https://github.com/aircrack-ng/rtl8814au, using Windows 10 in dual boot on the same PC and the same adapter. I read the readme.md file and installed with make dkms_install. Then reboot and the WiFi icon shows up in the up right corner with a question mark, but in the Settings->WiFi it says "connected". But when I tried the browser there was no connection. contradictory icons
Any ideas?
    sudo lshw -class network
[sudo] password di ernesto:
-network
description: Ethernet interface product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:03:00.0 logical name: enp3s0 version: 15 serial: 30:9c:23:67:84:9a capacity: 1Gbit/s width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.8.0-33-generic firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII resources: irq:18 ioport:d000(size=256) memory:df104000-df104fff memory:df100000-df103fff
-network description: Wireless interface physical id: 2 bus info: usb@2:1.4 logical name: wlx1062eb92c6aa serial: 10:62:eb:92:c6:aa capabilities: ethernet physical wireless configuration: broadcast=yes driver=8814au driverversion=5.8.0-33-generic ip=192.168.1.9 multicast=yes wireless=IEEE 802.11
lsusb Bus 002 Device 003: ID 0480:0820 Toshiba America Inc Canvio Advance Disk Bus 002 Device 005: ID 2001:331a D-Link Corp. External USB 3.0 Bus 002 Device 004: ID 1058:0730 Western Digital Technologies, Inc. My Passport Essential (WDBACY) Bus 002 Device 002: ID 05e3:0626 Genesys Logic, Inc. USB3.1 Hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 007: ID 046d:c083 Logitech, Inc. G403 Prodigy Gaming Mouse Bus 001 Device 009: ID 0c45:6536 Microdia Bus 001 Device 008: ID 046d:c52f Logitech, Inc. Unifying Receiver Bus 001 Device 006: ID 2109:2812 VIA Labs, Inc. VL812 Hub Bus 001 Device 005: ID 046d:c313 Logitech, Inc. Internet 350 Keyboard Bus 001 Device 003: ID 1949:000d Lab126, Inc. Android Bus 001 Device 004: ID 1038:1250 SteelSeries ApS USB2.1 Hub Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
rfkill list all 0: phy0: Wireless LAN Soft blocked: no Hard blocked: no
dkms status 8192cu, 1.11, 5.4.0-58-generic, x86_64: installed 8814au, 5.8.5.1, 5.8.0-33-generic, x86_64: installed (WARNING! Diff between built and installed module!) btusb, 4.0, 5.4.0-58-generic, x86_64: installed btusb, 4.0, 5.8.0-33-generic, x86_64: installed nvidia, 450.80.02, 5.4.0-58-generic, x86_64: installedError! Could not locate dkms.conf file. File: /var/lib/dkms/rtl88x2bu/5.3.1/source/dkms.conf does not exist.
nvidia, 450.80.02, 5.8.0-33-generic, x86_64: installed rtl8812au, 5.6.4.1: added rtl8814AU, 4.3.21: added rtl8814au, 5.8.5.1: added
KazikM
  • 251
Sqr
