Since installing Ubuntu 12.04, I've been having a problem with the mouse pointer size. On the desktop, it is quite a bit larger than it should be (24), though the different cursors (editing text, hyperlink hand, etc) are correct. The size changes to the correct size when the pointer is over some application windows (GVim, Netbeans, Firefox), but then changes back once it is moved out of the window.
There was a similar question here, but the Xdefaults solution did not work for me, and I didn't want to try the one requiring editing the icon image. In addition, I've tried changing the cursor theme using
sudo update-alternatives --config x-cursor-theme
as well as using the dconf-editor, but though I can change the theme, the size issue remains.
In case it's relevant, I'm running on a dual-screen setup with monitor sizes of 2560x1600 and 1920x1080, using the NVidia video driver. Is there another way to control pointer size, or a setting that might be messing it up?
EDIT: These are the values/options I have for update-alternatives and in dconf-editor. I'm now wondering if Netbeans and Firefox are making the mouse pointer smaller than it should be, but I'm not sure how big 24 should be...
update-alternatives:
  Selection    Path                                     Priority   Status
  0            /usr/share/icons/DMZ-White/cursor.theme   90        auto mode
  1            /etc/X11/cursors/core.theme               30        manual mode
  2            /etc/X11/cursors/handhelds.theme          20        manual mode
  3            /etc/X11/cursors/redglass.theme           20        manual mode
  4            /etc/X11/cursors/whiteglass.theme         20        manual mode
* 5            /usr/share/icons/DMZ-Black/cursor.theme   30        manual mode
  6            /usr/share/icons/DMZ-White/cursor.theme   90        manual mode
dconf-editor:
I can't post the image since I'm a new user but the cursor-size is set to 24 and the cursor-theme is DMZ-Black.
This is actually a bug, however, there is a known solution.
First, edit your /etc/X11/Xresources/x11-common file:
sudo nano /etc/X11/Xresources/x11-common
Now, add this to or edit the file to include the following:
Xcursor.size: 22
Xcursor.theme: DMZ-Black
Known sizes are 8, 16, 22, 24, 32
Press CTRL + o and then press ENTER to save the file. Press CTRL + x to exit nano.
Log out and then log back in or restart your xsession to apply the changes.
Personally, I use Adwaita instead of DMZ-Black. Adwaita is a quite similar black cursor but has a different spinning icon for when the system is busy.
You can install it:
sudo apt-get install adwaita-icon-theme-full
Then, set the file like so:
Xcursor.size: 22
Xcursor.theme: Adwaita
source: bugs.launchpad.net
See this related answer for how to change the cursor size on certain applications.
mchid
  • 44,904
  • 102
  • 162
EDIT : After further testing by undoing all my manipulations, I found out that the sudo update-alternatives --config x-cursor-theme command to choose one among cursors with manual mode was sufficient.
My mistake was that I only logged out from my session after each change. This wasn't sufficient. You have to reboot your system after this change !
misstux84
  • 41
im using xfce4 on centos7 on a lenovo p72 with 4k screen. I had the huge mouse cursor issue also. The following worked for me:
add the following lines to /etc/X11/xresources
Xcursor.size: 16
Log off and on again (or reboot).
Now you should have a standard (although a little small for a 4k screen) mouse pointer.
