I have a laptop with 2 HDD drives, an M.2 SSD and a SATA SSD. I was using Windows 10, but I changed to Kubuntu 20.04.1 LTS. I installed the OS to a complete new M.2 SSD, and I let the SATA HDD as it was with the files (as when I used it on the windows). The problem now is that when I try to write to the files on the SATA HDD, I cannot due to access privileges. I looked at the properties labels and I haven't succeeded in changing this. Any ideas? I am googling it but I do not find a similar situation.
Asked
Active
Viewed 104 times
Ok, here is the solution to my problem. I opened the laptop, I removed the SATA HDD, I used a USB to SATA adapter and I connect it to a Windows 10 OS, then I safely removed the HDD and I disassembled from the adapter. I connected back to the Linux OS laptop, and turned it on. It works perfectly now. No backup, no copy-paste.
john
- 151
- 2
- 11
