I want to install noise player (beatbox's fork player) on ubuntu 12.04, but when i try i get this error:
Reading package lists... Done
Building dependency tree
 noise : Depends: libtagc0 (>= 1.5) but it is not installable
obviously I added the necesary ppa's
sudo add-apt-repository ppa:nemequ/sqlheavy
sudo add-apt-repository ppa:elementary-os/daily
sudo apt-get update
sudo apt-get install noise
but ubuntu does not have libtagc0 installed, then i try to install libtagc0 with:
sudo apt-get update
sudo apt-get install libtagc0-dev
but i got a error menssage:
E: Unable to locate package libtagc0-dev
I've tried to fix the broken packages with:
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
But any command didn't work! now i just do not know how can i install the dependency (libtagc0) to could install my favorite music player noise!
Thanks in advance for any help
Rinzwind
  • 309,379
Kesymaru
  • 341
Manual install can be an option. You can find the DEB on ubuntuupdates. Use the apt install on the website. And after that try and install beatbox.
Rinzwind
  • 309,379
