After a necessairy boot repair, the kernel load time is significantly longer than normal: 34s. http://paste.ubuntu.com/p/s45GGcf22B I don't know how to fix that.
about: Long kernel load time the Intel Speed Step, on or off gave me both 34s for the kernel to load.
I don't understand this solution well: Is it normal for Ubuntu to take a long time to shut down after running the boot-repair program?
My grub menu seems to be on my Windows SSD and my Ubuntu on an other SSD.
I had to repair the boot since I accidently pulled out a data cable of one of my SSD drives. Luckily, I have access to my Windows and my Ubuntu.
Here is my startup script in the Grub Customizer for Ubuntu, causing the slow start:
Here is the script I found in the Grub customizer to launch my Ubuntu:
recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_msdos insmod ext2 set root='hd1,msdos1' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,msdos1 --hint-efi=hd1,msdos1 --hint-baremetal=ahci1,msdos1 c1d84984-8159-4a32-bf22-a30e1d0f33fe else search --no-floppy --fs-uuid --set=root c1d84984-8159-4a32-bf22-a30e1d0f33fe fi linux /boot/vmlinuz-4.15.0-128-generic root=UUID=c1d84984-8159-4a32-bf22-a30e1d0f33fe ro quiet splash $vt_handoff initrd /boot/initrd.img-4.15.0-128-generic
Rogonow
  • 101
I finally found the solution: Boot hangs for 30 seconds at "Begin: Running /scripts/local-premount" THe system searched for a swap file, which I don't have. I don't need a swap for my 8 GB!
Rogonow
  • 101
