I'm trying to install the Printer Canon LBP2900 in Ubuntu 20.04.
Canon has Linux drivers for the printer on their homepage and I successfully installed them. But they are not working out of the box. I found many sources, saying that the drivers are dependent on some 32bit packages that have to be installed manually to make it work (the solution seems to work well for older Ubuntu versions, 16.04 and 18.04). But in 20.04 it is not working:
Trying to install the packages in 20.04:
$ sudo apt-get -y install libatk1.0-0:i386 libcairo2:i386 libgtk2.0-0:i386 libpango1.0-0:i386 libstdc++6:i386 libpopt0:i386 libxml2:i386 libc6:i386
Reading package lists... Done
Building dependency tree
Note, selecting 'libpango-1.0-0:i386' instead of 'libpango1.0-0:i386'
libc6:i386 is already the newest version (2.31-0ubuntu9).
libpopt0:i386 is already the newest version (1.16-14).
libatk1.0-0:i386 : Depends: libglib2.0-0:i386 (>= 2.55.2) but it is not going to be installed
libcairo2:i386 : Depends: libfontconfig1:i386 (>= 2.12.6) but it is not going to be installed
Depends: libfreetype6:i386 (>= 2.9.1) but it is not going to be installed
Depends: libpng16-16:i386 (>= 1.6.2-1) but it is not going to be installed
Depends: zlib1g:i386 (>= 1:1.1.4) but it is not going to be installed
libgtk2.0-0:i386 : Depends: libcups2:i386 (>= 2.3~b6) but it is not going to be installed
Depends: libgdk-pixbuf2.0-0:i386 (>= 2.22.1) but it is not going to be installed
Depends: libglib2.0-0:i386 (>= 2.41.1) but it is not going to be installed
Depends: libpangocairo-1.0-0:i386 (>= 1.28.3) but it is not going to be installed
Depends: libpangoft2-1.0-0:i386 (>= 1.28.3) but it is not going to be installed
Recommends: libgail-common:i386 but it is not going to be installed
libpango-1.0-0:i386 : Depends: libglib2.0-0:i386 (>= 2.59.2) but it is not going to be installed
Depends: libharfbuzz0b:i386 (>= 2.1.1) but it is not going to be installed
libxml2:i386 : Depends: liblzma5:i386 (>= 5.1.1alpha+20120614) but it is not going to be installed
Depends: zlib1g:i386 (>= 1:1.2.3.3) but it is not going to be installed
It comes down to the issue, that Ubuntu denies installation for good reasons:
$ sudo apt install zlib1g:i386
... LONG LIST OF PACKAGES INSTALLED AND REMOVED ...
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
apt adduser (due to apt) gpgv (due to apt) libapt-pkg6.0 (due to apt) dash
dpkg (due to dash) debconf (due to dash) zlib1g (due to dpkg) grep
install-info (due to grep) gzip init systemd-sysv (due to init)
init-system-helpers (due to init) perl-base (due to init-system-helpers)
login libpam0g (due to login) libpam-runtime (due to login)
libpam-modules (due to login) mount util-linux (due to mount) sysvinit-utils
0 upgraded, 1 newly installed, 1109 to remove and 0 not upgraded.
Of course I won't because I know exactly what it would do ;-)
$ sudo apt-cache policy zlib1g zlib1g:i386
zlib1g:
Installiert: 1:1.2.11.dfsg-2ubuntu1.1
Installationskandidat: 1:1.2.11.dfsg-2ubuntu1.1
Versionstabelle:
*** 1:1.2.11.dfsg-2ubuntu1.1 100
100 /var/lib/dpkg/status
1:1.2.11.dfsg-2ubuntu1 500
500 http://de.archive.ubuntu.com/ubuntu focal/main amd64 Packages
zlib1g:i386:
Installiert: (keine)
Versionstabelle:
500 http://de.archive.ubuntu.com/ubuntu focal/main i386 Packages
- How can I still install these dependencies?
- Are there any replacements?
