I am installing kurento-media-server from official guide for Ubuntu in Windows Subsystem for Linux.
I executed these commands first:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 5AFA7A83
source /etc/upstream-release/lsb-release 2>/dev/null || source /etc/lsb-release
sudo tee "/etc/apt/sources.list.d/kurento.list" >/dev/null <<EOF
Kurento Media Server - Release packages
deb [arch=amd64,trusted=yes] http://ubuntu.openvidu.io/6.15.0 $DISTRIB_CODENAME focal kms6
EOF
After that this happened :
root@DESKTOP-PRK1GBK:~# sudo apt-get update
Err:1 http://ubuntu.openvidu.io/6.10.0 focal InRelease
403 Forbidden [IP: 52.218.106.43 80]
Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:5 http://security.ubuntu.com/ubuntu focal-security InRelease
Reading package lists... Done
E: Failed to fetch http://ubuntu.openvidu.io/6.10.0/dists/focal/InRelease 403 Forbidden [IP: 52.218.106.43 80]
E: The repository 'http://ubuntu.openvidu.io/6.10.0 focal InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Theses are the contents of kurento.list file:
root@DESKTOP-PRK1GBK:~# cat /etc/apt/sources.list.d/kurento.list
# Kurento Media Server - Release packages
deb [arch=amd64,trusted=yes] http://ubuntu.openvidu.io/6.10.0 focal kms6
I have tried to use --allow-insecure-repositories and this is the output:
root@DESKTOP-PRK1GBK:~# sudo apt-get update --allow-insecure-repositories
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Ign:3 http://ubuntu.openvidu.io/6.10.0 focal InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Ign:5 http://ubuntu.openvidu.io/6.10.0 focal Release
Hit:6 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Ign:7 http://ubuntu.openvidu.io/6.10.0 focal/kms6 amd64 Packages
Ign:8 http://ubuntu.openvidu.io/6.10.0 focal/kms6 all Packages
Ign:9 http://ubuntu.openvidu.io/6.10.0 focal/kms6 Translation-en
Ign:10 http://ubuntu.openvidu.io/6.10.0 focal/kms6 all c-n-f Metadata
Ign:11 http://ubuntu.openvidu.io/6.10.0 focal/kms6 amd64 c-n-f Metadata
Err:7 http://ubuntu.openvidu.io/6.10.0 focal/kms6 amd64 Packages
403 Forbidden [IP: 52.218.105.226 80]
W: The repository 'http://ubuntu.openvidu.io/6.10.0 focal Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
E: Failed to fetch http://ubuntu.openvidu.io/6.10.0/dists/focal/kms6/binary-amd64/Packages 403 Forbidden [IP: 52.218.105.226 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
