I have installed atftpd on Ubuntu 12.04, but it looks like I cannot start the tftp server, and there's a problem also with the tftpd daemon. With Ubuntu 11.10 there was no problem.
ureadahead will be reprofiled on next reboot
atftpd (0.7.dfsg-11) wird eingerichtet ...
unknown protocol: udp4
With rlinetd, and also as daemon, it doesn't work.
with ps -afe I see no process.
/var/log/syslog says it cannot bind to ip address.
with option --bind-adress the atftpd server starts but also doesn't work.
belacqua
  • 23,540
I've checked out atftpd source code, and find out that working line for /etc/default/atftpd is
USE_INETD=false
OPTIONS="--tftpd-timeout 300 --retry-timeout 5 --port=69 --maxthread 100 --verbose=5 /srv/tftp"
You need to specify port to fool atftpd. So now tftp server is available from all network interfaces.
You are probably affected by bug #993101
Please confirm if you are having same problem! Eventually, you can always download the source and install by yourself..
confiq
  • 180
This is how I got atftpd working in 12.04:
  1. Edit /etc/default/atftpd
    a. Change inetd=true to inetd=false
    b. Removed all multicast options, added --bind-address=<my local static ip>
    c. Created /tftpboot directory (modify /etc/default/atftpd accordingly as the default directory is something else) with user nobody group nogroup
    d. Also added --logfile /var/log/atftpd.log (first touch /var/log/atftpd.log and set permissions accordingly)
    e. Set --verbose=7 to capture all messages
  2. Edit /etc/rlinetd.conf and made services available only local network by specifying my interface as my local IP address.
  3. Stopped started rlinetd
  4. Ran invoke-rc.d atftpd start as root.
Hope this is useful.
Peachy
  • 7,235
  • 40
  • 47
Ubuntu 12.04 LTS
This system has an ip address of 192.168.0.5
sudo touch /var/log/atftpd.log
sudo chmod 644 /var/log/atftpd.log
here's my /etc/default/atftpd
USE_INETD=false
OPTIONS="--port=69 --tftpd-timeout 300 --retry-timeout 5 --mcast-port 1758 --mca
st-addr 192.168.0.0-255 --mcast-ttl 1 --maxthread 100 --verbose=7 /tftpboot --lo
gfile /var/log/atftpd.log"
sudo mkdir /tftpboot
sudo chmod 777 /tftpboot
touch /tftpboot/simple.txt
sudo invoke-rc.d atftpd restart
From another system (on the same subnet) running busybox
tftp -l simple.txt -g 192.168.0.5
