My current /etc/netplan/wifi.yaml looks like this:
network:
  version: 2
  renderer: networkd
  wifis:
    wlan0:
      dhcp4: yes
      optional: true
      access-points:
        "myssid":
          "mypw"
Then netplan generate produces /run/netplan/wpa-wlan0.conf:
ctrl_interface=/run/wpa_supplicant
network={ ssid="myssid" key_mgmt=WPA-PSK psk="mypw" }
How to add country=NL to it without losing it after the next netplan generate?
Or is there another way to specify the Wi-Fi region?
I'm running Ubuntu 20.10 on Raspberry Pi 4 64-bit, if it matters.
rustyx
  • 1,066
  • 15
  • 17
Netplan supports a regulatory-domain: NL setting, as of v0.105, so you should be able to adopt your configuration to something like this:
network:
  version: 2
  renderer: networkd
  wifis:
    wlan0:
      regulatory-domain: "NL"
      dhcp4: yes
      optional: true
      access-points:
        "myssid":
          "mypw"
See: https://netplan.io/reference#properties-for-device-type-wifis
Slyon
  • 462
-1
Just try the iw reg way:
iw reg set
from: https://wiki.archlinux.org/title/Network_configuration/Wireless#Device_driver
