I have tried every solution I can find on the net from many different sites. I start out with: sudo apt upgrade and then: sudo apt upgrade, but as you can see I wind up with unmet dependencies
michael@Ubuntu:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 nodejs : Depends: libnode72 (= 12.18.2~dfsg-1ubuntu2) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
To fix the unmet dependencies I run: sudo apt --fix-broken install: michael@Ubuntu:~$ sudo apt --fix-broken install Reading package lists... Done Building dependency tree
Reading state information... Done Correcting dependencies... Done The following packages were automatically installed and are no longer required: gyp javascript-common libjs-inherits libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer libssl-dev libuv1-dev node-abbrev node-ajv node-ansi node-ansi-align node-ansi-regex node-ansi-styles node-ansistyles node-aproba node-archy node-are-we-there-yet node-asap node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bl node-bluebird node-boxen node-brace-expansion node-builtin-modules node-builtins node-cacache node-call-limit node-camelcase node-caseless node-chalk node-chownr node-ci-info node-cli-boxes node-cliui node-clone node-co node-color-convert node-color-name node-colors node-columnify node-combined-stream node-concat-map node-concat-stream node-config-chain node-configstore node-console-control-strings node-copy-concurrently node-core-util-is node-cross-spawn node-crypto-random-string node-cyclist node-dashdash node-debbundle-es-to-primitive node-debug node-decamelize node-decompress-response node-deep-extend node-defaults node-define-properties node-delayed-stream node-delegates node-detect-indent node-detect-newline node-dot-prop node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding node-end-of-stream node-err-code node-errno node-es6-promise node-escape-string-regexp node-execa node-extend node-extsprintf node-fast-deep-equal node-find-up node-flush-write-stream node-forever-agent node-form-data node-from2 node-fs-vacuum node-fs-write-stream-atomic node-fs.realpath node-function-bind node-gauge node-genfun node-get-caller-file node-get-stream node-getpass node-glob node-got node-graceful-fs node-har-schema node-har-validator node-has-flag node-has-symbol-support-x node-has-to-string-tag-x node-has-unicode node-hosted-git-info node-http-signature node-iconv-lite node-iferr node-import-lazy node-imurmurhash node-inflight node-inherits node-ini node-invert-kv node-ip node-ip-regex node-is-npm node-is-obj node-is-object node-is-path-inside node-is-plain-obj node-is-retry-allowed node-is-stream node-is-typedarray node-isarray node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream node-jsprim node-latest-version node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile node-lodash node-lodash-packages node-lowercase-keys node-lru-cache node-make-dir node-mem node-mime node-mime-types node-mimic-fn node-mimic-response node-minimatch node-minimist node-mississippi node-mkdirp node-move-concurrently node-ms node-mute-stream node-nopt node-normalize-package-data node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-number-is-nan node-oauth-sign node-object-assign node-once node-opener node-os-locale node-os-tmpdir node-osenv node-p-cancelable node-p-finally node-p-is-promise node-p-limit node-p-locate node-p-timeout node-package-json node-parallel-transform node-path-exists node-path-is-absolute node-path-is-inside node-performance-now node-pify node-prepend-http node-process-nextick-args node-promise-inflight node-promise-retry node-promzard node-proto-list node-prr node-pseudomap node-psl node-pump node-pumpify node-punycode node-qs node-qw node-rc node-read node-read-package-json node-readable-stream node-registry-auth-token node-registry-url node-request node-require-directory node-require-main-filename node-resolve node-resolve-from node-retry node-rimraf node-run-queue node-safe-buffer node-semver node-semver-diff node-set-blocking node-sha node-shebang-command node-shebang-regex node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct node-spdx-exceptions node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri node-stream-each node-stream-iterate node-stream-shift node-strict-uri-encode node-string-decoder node-string-width node-strip-ansi node-strip-eof node-strip-json-comments node-supports-color node-tar node-term-size node-text-table node-through node-through2 node-timed-out node-tough-cookie node-tunnel-agent node-tweetnacl node-typedarray node-typedarray-to-buffer node-uid-number node-unique-filename node-unique-string node-unpipe node-uri-js node-url-parse-lax node-url-to-options node-util-deprecate node-uuid node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js node-which node-which-module node-wide-align node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic node-xdg-basedir node-xtend node-y18n node-yallist node-yargs node-yargs-parser nodejs-doc Use 'sudo apt autoremove' to remove them. The following additional packages will be installed: nodejs The following packages will be upgraded: nodejs 1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. Need to get 0 B/18.4 MB of archives. After this operation, 94.2 MB of additional disk space will be used. Do you want to continue? [Y/n] Y (Reading database ... 193811 files and directories currently installed.) Preparing to unpack .../nodejs_12.20.0-deb-1nodesource1_amd64.deb ... Unpacking nodejs (12.20.0-deb-1nodesource1) over (12.18.2~dfsg-1ubuntu2) ... dpkg: error processing archive /var/cache/apt/archives/nodejs_12.20.0-deb-1nodes ource1_amd64.deb (--unpack): trying to overwrite '/usr/share/doc/nodejs/api/perf_hooks.html', which is also in package nodejs-doc 12.18.2~dfsg-1ubuntu2 dpkg-deb: error: paste subprocess was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/nodejs_12.20.0-deb-1nodesource1_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
And I get the broken pipes error. It's a viscous circle. I can't break it with the right answer. So, please some kind sole help a guy out and give me some insight. Thanks in advance.
dariofac
  • 1,042
You can try to solve it by opening the Terminal (tipically Ctrl + Alt + T) and from there executing
sudo dpkg -i --force-overwrite /var/cache/apt/archives/nodejs_12.20.0-deb-1nodesource1_amd64.deb
and then
sudo apt -f install
dariofac
  • 1,042
Your problem seems clearly stated in your output:
Let's tease this apart a bit so it's readable:
A = nodejs_12.20.0-deb-1nodesource1_amd64.deb
B = nodejs-doc 12.18.2~dfsg-1ubuntu2
dpkg: error processing A (--unpack): trying to overwrite '/usr/share/doc/nodejs/api/perf_hooks.html', which is also in B
In other words, package A and package B conflict. You cannot have both installed simultaneously. Only one at a time.
A and B are from different sources, and are different versions (which also won't work).
The problem occurred because you unwisely mixed sources. Pick a single, uniform source to install your node packages from...and stick to it.
user535733
  • 68,493
