So when I try to install just wine it goes without a problem, however it obviously does not install wine32 which is needed for the applications I want to run.
I've already added sudo dpkg --add-architecture i386
However when I try to sudo apt install wine32 I get these errors:
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libavcodec58 : Breaks: libavcodec58:i386 (!= 7:4.2.4-1ubuntu0.1)
libavcodec58:i386 : Depends: libaom0:i386 (>= 1.0.0) but it is not going to be installed
Depends: libavutil56:i386 (= 7:4.3.1-5) but it is not going to be installed
Depends: libcairo2:i386 (>= 1.2.4) but it is not going to be installed
Depends: libcodec2-0.9:i386 (>= 0.9.2) but it is not going to be installed
Depends: libdav1d4:i386 (>= 0.2.1) but it is not installable
Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed
Depends: libgsm1:i386 (>= 1.0.18) but it is not going to be installed
Depends: libmp3lame0:i386 (>= 3.100) but it is not going to be installed
Depends: libopenjp2-7:i386 (>= 2.0.0) but it is not going to be installed
Depends: libopus0:i386 (>= 1.1) but it is not going to be installed
Depends: librsvg2-2:i386 (>= 2.14.4) but it is not going to be installed
Depends: libshine3:i386 (>= 3.1.0) but it is not going to be installed
Depends: libsnappy1v5:i386 (>= 1.1.8) but it is not going to be installed
Depends: libspeex1:i386 (>= 1.2~beta3-1) but it is not going to be installed
Depends: libswresample3:i386 (= 7:4.3.1-5) but it is not going to be installed
Depends: libtheora0:i386 (>= 1.0) but it is not going to be installed
Depends: libtwolame0:i386 (>= 0.3.10) but it is not going to be installed
Depends: libva2:i386 (>= 2.2.0) but it is not going to be installed
Depends: libvorbis0a:i386 (>= 1.1.2) but it is not going to be installed
Depends: libvorbisenc2:i386 (>= 1.1.2) but it is not going to be installed
Depends: libvpx6:i386 (>= 1.6.0) but it is not going to be installed
Depends: libwavpack1:i386 (>= 4.40.0) but it is not going to be installed
Depends: libwebp6:i386 (>= 0.5.1) but it is not going to be installed
Depends: libwebpmux3:i386 (>= 0.6.1-2+b1) but it is not going to be installed
Depends: libx264-160:i386 (>= 2:0.160.3011+gitcde9a93) but it is not installable
Depends: libx265-192:i386 (>= 3.2) but it is not installable
Depends: libxvidcore4:i386 (>= 1.2.2) but it is not going to be installed
Depends: libzvbi0:i386 (>= 0.2.35) but it is not going to be installed
Breaks: libavcodec58 (!= 7:4.3.1-5)
wine32:i386 : Depends: libwine:i386 (= 5.0-3ubuntu1) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages
After a deeper look it seems that there are 2 problems:
1) Some dependencies "break" each other
2) Many dependecies are required in a version that is just not available from Ubuntu 20.04
Can I somehow force wine32 install to install dependencies with the needed versions?
Sidenote: wine broke after an upgrade from Ubuntu 18.04 to 20.04, on 18.04 I somehow got it working just fine using add architecture and the winehq repository...
EDIT
repositories
Currently disabled (was enabled while I was trying to debug this)
https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ (regular & source)
Currently enabled
https://dl.winehq.org/wine-builds/ubuntu/ (regular & source)
output of apt-cache policy wine32
wine32:i386:
Installed: (none)
Candidate: 5.0-3ubuntu1
Version table:
5.0-3ubuntu1 500
500 http://archive.ubuntu.com/ubuntu focal/universe i386 Packages
output of grep -ir ^deb /etc/apt/ --include=*.list
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu focal main universe restricted multiverse
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu/ focal-security restricted universe multiverse main
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu focal-updates restricted universe multiverse main
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu focal-backports restricted universe multiverse main
/etc/apt/sources.list:deb https://dl.winehq.org/wine-builds/ubuntu/ focal main
/etc/apt/sources.list:deb-src https://dl.winehq.org/wine-builds/ubuntu/ focal main
When I've disabled all those repositories and purge all wine and ran autoremove and clean and autoclean and apt update, then tried to sudo apt install wine32 the output is now:
Output of apt-cache policy wine32 remains the same output of grep -ir ^deb /etc/apt/ --include=*.list is reduced by the removed repos.
EDIT 2:
apt-cache policy libwine:i386
libwine:i386:
Installed: (none)
Version table:
5.0-3ubuntu1 500
dpkg -l | grep -i wine => no results
sudo apt-get install libwine:i386
Reading package lists... Done
libwine:i386 : Depends: libfaudio0:i386 (>= 19.06.07) but it is not going to be installed
Depends: libgphoto2-6:i386 (>= 2.5.10) but it is not going to be installed
Depends: libgstreamer-plugins-base1.0-0:i386 (>= 1.0.0) but it is not going to be installed
Depends: libgstreamer1.0-0:i386 (>= 1.4.0) but it is not going to be installed
Depends: libxml2:i386 (>= 2.9.0) but it is not going to be installed
Recommends: libcups2:i386 (>= 1.4.0) but it is not going to be installed
Recommends: libgssapi-krb5-2:i386 (>= 1.6.dfsg.2) but it is not going to be installed
Recommends: libkrb5-3:i386 (>= 1.6.dfsg.2) but it is not going to be installed
Recommends: libsane:i386 (>= 1.0.24) but it is not going to be installed
Recommends: libxslt1.1:i386 (>= 1.1.25) but it is not going to be installed
Recommends: gstreamer1.0-plugins-good:i386 but it is not going to be installed
