I'm trying to mount a Windows partition in my Ubuntu system so I edited fstab with this:
/dev/sda4 /mnt/windows ntfs rw,auto 0 0
This mounts without any problem my Windows partition into /mnt/windows but when I try to access to an especific folder I find this with ls -l:
-rwxrwxrwx 2 root root 844 oct 6 17:21 'Universidad - Acceso directo.lnk'
and I cannot access using cd.
I tried using lnkinfo to see if it was usefull to me but it wasn't.
Windows Shortcut information:
Contains a link target identifier
Link information:
Creation time : Sep 12, 2018 11:54:32.625892600 UTC
Modification time : Sep 29, 2020 15:12:40.035328300 UTC
Access time : Sep 29, 2020 15:12:40.035328300 UTC
File size : 4096 bytes
Icon index : 0
Show Window value : 0x00001000
Hot Key value : 4096
File attribute flags : 0x00000010
Is directory (FILE_ATTRIBUTE_DIRECTORY)
Drive type : Fixed (3)
Drive serial number : 0xb65790ec
Volume label : FREEDOS
Local path : D:\Escritorio\Universidad
Link target identifier:
Shell item list
Number of items : 3
Shell item: 1
Item type : Root folder
Class type indicator : 0x1f (Root folder)
Shell folder identifier : 20d04fe0-3aea-1069-a2d8-08002b30309d
Shell folder name : My Computer
Shell item: 2
Item type : Volume
Class type indicator : 0x2e (Volume)
Extension block: 1
Signature : 0xbeef0026
Shell item: 3
Item type : File entry
Class type indicator : 0x31 (File entry: Directory)
Modification time : Sep 29, 2020 15:12:42
Extension block: 1
Signature : 0xbeef0004 (File entry extension)
Long name : Universidad
Creation time : Sep 12, 2018 11:54:34
Access time : Sep 29, 2020 15:12:42
NTFS file reference : MFT entry: 45880, sequence: 1
How can I fix it and access to the folder? In Windows the folder it's not a direct access.
I'm using Ubuntu 18.04 and mounting Windows 10.
Thank you!
