When I try to use CUDA with Blender 2.82.a+dfsg-1 I get the following error:
Compiling CUDA kernel ...
"nvcc" -arch=sm_86 --cubin "/usr/share/blender/scripts/addons/cycles/source/kernel/kernels/cuda/kernel.cu" -o "/home/bram/.cache/cycles/kernels/cycles_kernel_sm86_673C3180FADE8EDF0E80E61994C4DC92.cubin" -m64 --ptxas-options="-v" --use_fast_math -DNVCC -I"/usr/share/blender/scripts/addons/cycles/source"
nvcc fatal   : Value 'sm_86' is not defined for option 'gpu-architecture'
CUDA kernel compilation failed, see console for details.
CUDA 11.1 is installed on my system, as is reported by nvidia-smi
$ nvidia-smi
Sun Dec 20 19:34:48 2020
| NVIDIA-SMI 455.38       Driver Version: 455.38       CUDA Version: 11.1     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce RTX 3070    Off  | 00000000:17:00.0  On |                  N/A |
|  0%   55C    P8    19W / 240W |    610MiB /  7979MiB |     12%      Default |
|                               |                      |                  N/A |
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 968 G /usr/lib/xorg/Xorg 59MiB | | 0 N/A N/A 1598 G /usr/lib/xorg/Xorg 247MiB | | 0 N/A N/A 1749 G /usr/bin/gnome-shell 74MiB | | 0 N/A N/A 3855 G ...e/Steam/ubuntu12_32/steam 17MiB | | 0 N/A N/A 3866 G ./steamwebhelper 3MiB | | 0 N/A N/A 3878 G ...43331726878339,131072 --d 49MiB | | 0 N/A N/A 5384 G /usr/lib/firefox/firefox 3MiB | | 0 N/A N/A 5463 G /usr/lib/firefox/firefox 3MiB | | 0 N/A N/A 5686 G nvidia-settings 3MiB | | 0 N/A N/A 9586 G /usr/lib/firefox/firefox 3MiB | | 0 N/A N/A 9642 G blender 120MiB | | 0 N/A N/A 9988 G /usr/lib/firefox/firefox 3MiB | +-----------------------------------------------------------------------------+
How can I force blender to use a different shader-model? because apparently, it does not like sm_86.
Bram
  • 3,699
Check the allowed values for gpu-architecture with
nvcc --help
For my CUDA 10.1 install, I get:
Allowed values for this option:  'compute_30','compute_32','compute_35',
        'compute_37','compute_50','compute_52','compute_53','compute_60','compute_61',
        'compute_62','compute_70','compute_72','compute_75','sm_30','sm_32','sm_35',
        'sm_37','sm_50','sm_52','sm_53','sm_60','sm_61','sm_62','sm_70','sm_72',
        'sm_75'.
So sm_86 is not an allowed value.
ubfan1
  • 19,049
The CUDA version that command nvidia-smi shows is not your current actual CUDA version but your maximum CUDA version.
The actual CUDA version can be show by command nvcc -V or nvcc --version, may be your actual CUDA version is lower than 11.1, so you need to update it to 11.1 or later. You can search for special update process tutorial, here are CUDA Toolkit Archive
For me, command nvidia-smi shows 12.2, while command nvcc -V shows 11.5, and the fault I met is Value 'sm_89' is not defined for option 'gpu-architecture', after I update my CUDA version to 12.2, it doesn't show the fault.
Maybe it can help you.
