I freshly installed ubuntu , didnt expected this. and it has never happened before atleast for ubuntu 20.04.1 LTS . I did ran sudo apt update then I tried to install.
$ sudo apt install openssh-server -y
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies. openssh-server : Depends: openssh-client (= 1:8.2p1-4) Depends: openssh-sftp-server Recommends: ssh-import-id but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I installed ssh-import-id and then tried to installed openss-sftp-server but I still get thsi depends error.
