There are different pre-built images available for Raspberry Pis, both in desktop and server variants, etc.
In my situation, I want to build a much more slimmer image with some configurations made long before the first boot and with fewer preinstalled packages as I won't use them at all. Modifying pre-built images isn't good as it isn't a clean approach.
I found same question there, but it points to manifest files, which just contain names and versions of installed packages. That info, of course, isn't enough to create functional image from scratch.
How are the pre-built Ubuntu images for Raspberry Pi actually made?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
I'm not sure how they're built
this page might help
prerequisites :
sudo apt-get install gparted
step 1 - clone SD card of raspbery with software you want
sudo fdisk -l
check which /dev/sdx is the SD card
clone SD card to image on PC
sudo dd if=/dev/sdb of=/your/path/to/clone.img
step 2 - shrink image
wget  https://raw.githubusercontent.com/Drewsif/PiShrink/master/pishrink.sh
chmod +x pishrink.sh
sudo mv pishrink.sh /usr/local/bin
sudo pishrink.sh /your/path/to/clone.img /your/path/to/clone-shrink.img
step 3 - flash new image to SD
Download the Etcher (www.etcher.io) application for your OS and select your newly shrunken image, then select the new SD card and click the button Flash And you are all good
step 4 - optional
to share the image with others are store it in smaller you can compress it to have a smaller storage/sending size
gzip -9 /your/path/to/clone-shrink.img
original site :
https://medium.com/platformer-blog/creating-a-custom-raspbian-os-image-for-production-3fcb43ff3630
Koen
  • 1,277
