After consecutively upgrading from 17.xx to 18.04 and the 20.04 I can not install apps from softwaremanager and grub does not show up anymore while booting so that I can not access my windows installation. There seems to be a problem with old kernels not being removed. Please help.
sudo apt autoremove gives:
marco@marco-ThinkPad:~$ sudo apt autoremove
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  linux-image-4.10.0-37-generic linux-image-4.13.0-45-generic linux-image-4.13.0-46-generic
  linux-image-extra-4.13.0-45-generic linux-image-extra-4.13.0-46-generic
0 upgraded, 0 newly installed, 5 to remove and 0 not upgraded.
5 not fully installed or removed.
After this operation, 547 MB disk space will be freed.
Do you want to continue? [J/n] j
(Reading database ... 426584 files and directories currently installed.)
Removing linux-image-4.10.0-37-generic (4.10.0-37.41) ...
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.10.0-37-generic /boot/vmlinuz-4.10.0-37-g
eneric
update-initramfs: Deleting /boot/initrd.img-4.10.0-37-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.10.0-37-generic /boot/vmlinuz-4.10.0-37-ge
neric
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.4.0-58-generic
Found initrd image: /boot/initrd.img-5.4.0-58-generic
Found linux image: /boot/vmlinuz-4.15.0-128-generic
Found initrd image: /boot/initrd.img-4.15.0-128-generic
/etc/grub.d/bin/grubcfg_proxy: error while loading shared libraries: libcrypto.so.1.0.0: cannot open
shared object file: No such file or directory
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127
Failed to process /etc/kernel/postrm.d at /var/lib/dpkg/info/linux-image-4.10.0-37-generic.postrm lin
e 330.
dpkg: error processing package linux-image-4.10.0-37-generic (--remove):
 installed linux-image-4.10.0-37-generic package post-removal script subprocess returned error exit s
tatus 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
ls -al /etc/grub.d gives:
marco@marco-ThinkPad:~$ ls -al /etc/grub.d
insgesamt 196
drwxr-xr-x   5 root root  4096 Dez 19 14:48 .
drwxr-xr-x 150 root root 12288 Dez 19 16:45 ..
-rwxr-xr-x   1 root root 10627 Nov 13 00:15 00_header
-rwxr-xr-x   1 root root  6258 Mär 15  2016 05_debian_theme
-rwxr-xr-x   1 root root 17622 Nov 13 00:15 10_linux
-rwxr-xr-x   1 root root   948 Jan 21  2017 10_linux_proxy
-rwxr-xr-x   1 root root 42359 Nov 13 00:15 10_linux_zfs
-rwxr-xr-x   1 root root 12894 Nov 13 00:15 20_linux_xen
-rwxr-xr-x   1 root root 12059 Jun 14  2017 30_os-prober.dpkg-dist
-rwxr-xr-x   1 root root   198 Jan 21  2017 30_os-prober_proxy
-rwxr-xr-x   1 root root  1424 Nov 13 00:15 30_uefi-firmware
-rwxr-xr-x   1 root root   948 Jan 21  2017 31_linux_proxy
-rwxr-xr-x   1 root root 11082 Jun 17  2016 32_linux_xen
-rwxr-xr-x   1 root root  1992 Jan 28  2016 33_memtest86+
-rwxr-xr-x   1 root root   198 Jan 21  2017 34_os-prober_proxy
-rwxr-xr-x   1 root root  1418 Jun 17  2016 35_uefi-firmware
-rwxr-xr-x   1 root root   214 Jun 17  2016 40_custom
-rwxr-xr-x   1 root root   216 Jun 17  2016 41_custom
drwxr-xr-x   4 root root  4096 Aug 10  2016 backup
drwxr-xr-x   2 root root  4096 Aug 10  2016 bin
drwxr-xr-x   2 root root  4096 Jan 21  2017 proxifiedScripts
-rw-r--r--   1 root root   483 Jun 17  2016 README
-rw-r--r--   1 root root   210 Jan 21  2017 .script_sources.txt
All the commands from the 1st answer below gave:
marco@marco-ThinkPad:~$ sudo chmod -x /etc/grub.d/30_os-prober_proxy
[sudo] Passwort für marco:
marco@marco-ThinkPad:~$ sudo chmod -x /etc/grub.d/10_linux_proxy
marco@marco-ThinkPad:~$ sudo chmod -x /etc/grub.d/31_linux_proxy
marco@marco-ThinkPad:~$ sudo mv /etc/grub.d/proxifiedScripts $HOME
marco@marco-ThinkPad:~$ sudo mv /etc/grub.d/bin $HOME/bin.bak
marco@marco-ThinkPad:~$ sudo mv /etc/grub.d/backup  $HOME/backup.bak
marco@marco-ThinkPad:~$ sudo mv /etc/grub.d/30_os-prober.dpkg-dist  /etc/grub.d/30_os-prober
marco@marco-ThinkPad:~$ df -h;df -i
Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
udev            3,9G       0  3,9G    0% /dev
tmpfs           785M    2,1M  783M    1% /run
/dev/sda7       106G     29G   72G   29% /
tmpfs           3,9G       0  3,9G    0% /dev/shm
tmpfs           5,0M    4,0K  5,0M    1% /run/lock
tmpfs           3,9G       0  3,9G    0% /sys/fs/cgroup
/dev/loop0      119M    119M     0  100% /snap/chromium/1424
/dev/loop2      144M    144M     0  100% /snap/firefox/372
/dev/loop3       62M     62M     0  100% /snap/core20/904
/dev/loop4       55M     55M     0  100% /snap/core18/1754
/dev/loop6      151M    151M     0  100% /snap/git-cola/136
/dev/loop5      147M    147M     0  100% /snap/git-cola/61
/dev/loop1       98M     98M     0  100% /snap/core/10577
/dev/loop7      147M    147M     0  100% /snap/firefox/469
/dev/loop8      163M    163M     0  100% /snap/gnome-3-28-1804/145
/dev/loop9      291M    291M     0  100% /snap/vlc/1620
/dev/loop10     261M    261M     0  100% /snap/kde-frameworks-5-core18/32
/dev/loop11     291M    291M     0  100% /snap/vlc/1700
/dev/loop12      65M     65M     0  100% /snap/gtk-common-themes/1514
/dev/loop13      63M     63M     0  100% /snap/gtk-common-themes/1506
/dev/loop14      98M     98M     0  100% /snap/core/9289
/dev/loop15     173M    173M     0  100% /snap/spotify/43
/dev/loop16     256M    256M     0  100% /snap/gnome-3-34-1804/36
/dev/loop17      56M     56M     0  100% /snap/core18/1944
/dev/loop18      52M     52M     0  100% /snap/snap-store/518
/dev/loop19     164M    164M     0  100% /snap/spotify/41
/dev/loop20     234M    234M     0  100% /snap/gimp/322
/dev/loop21     162M    162M     0  100% /snap/gnome-3-28-1804/128
/dev/loop22     218M    218M     0  100% /snap/gnome-3-34-1804/60
/dev/loop23     2,3M    2,3M     0  100% /snap/gnome-system-monitor/148
/dev/loop24     141M    141M     0  100% /snap/gnome-3-26-1604/100
/dev/sda2       256M     62M  195M   24% /boot/efi
tmpfs           785M     48K  785M    1% /run/user/1000
Dateisystem     Inodes IBenutzt   IFrei IUse% Eingehängt auf
udev            996636      644  995992    1% /dev
tmpfs          1003741     1314 1002427    1% /run
/dev/sda7      7061504   517323 6544181    8% /
tmpfs          1003741        1 1003740    1% /dev/shm
tmpfs          1003741        5 1003736    1% /run/lock
tmpfs          1003741       18 1003723    1% /sys/fs/cgroup
/dev/loop0        1330     1330       0  100% /snap/chromium/1424
/dev/loop2        2700     2700       0  100% /snap/firefox/372
/dev/loop3       11713    11713       0  100% /snap/core20/904
/dev/loop4       10764    10764       0  100% /snap/core18/1754
/dev/loop6       30231    30231       0  100% /snap/git-cola/136
/dev/loop5       30131    30131       0  100% /snap/git-cola/61
/dev/loop1       12867    12867       0  100% /snap/core/10577
/dev/loop7        2701     2701       0  100% /snap/firefox/469
/dev/loop8       27807    27807       0  100% /snap/gnome-3-28-1804/145
/dev/loop9       51065    51065       0  100% /snap/vlc/1620
/dev/loop10      35005    35005       0  100% /snap/kde-frameworks-5-core18/32
/dev/loop11      51155    51155       0  100% /snap/vlc/1700
/dev/loop12      63978    63978       0  100% /snap/gtk-common-themes/1514
/dev/loop13      62342    62342       0  100% /snap/gtk-common-themes/1506
/dev/loop14      12860    12860       0  100% /snap/core/9289
/dev/loop15      24071    24071       0  100% /snap/spotify/43
/dev/loop16      24339    24339       0  100% /snap/gnome-3-34-1804/36
/dev/loop17      10809    10809       0  100% /snap/core18/1944
/dev/loop18      15847    15847       0  100% /snap/snap-store/518
/dev/loop19      24012    24012       0  100% /snap/spotify/41
/dev/loop20      16728    16728       0  100% /snap/gimp/322
/dev/loop21      27798    27798       0  100% /snap/gnome-3-28-1804/128
/dev/loop22      18513    18513       0  100% /snap/gnome-3-34-1804/60
/dev/loop23        784      784       0  100% /snap/gnome-system-monitor/148
/dev/loop24      27624    27624       0  100% /snap/gnome-3-26-1604/100
/dev/sda2            0        0       0     - /boot/efi
tmpfs          1003741      101 1003640    1% /run/user/1000
marco@marco-ThinkPad:~$ sudo dpkg --configure -a && sudo apt -f install
-37-generic
37-generic
Found Windows Boot Manager on /dev/sda2@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings
/etc/grub.d/34_os-prober_proxy: 3: /etc/grub.d/34_os-prober_proxy: 3: /etc/grub.d/bin/grubcfg_pr
oxy: not found/etc/grub.d/proxifiedScripts/os-prober: not found
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127 Failed to process /etc/kernel/postrm.d at /var/lib/dpkg/info/linux-image-4.10.0-37-generic.postr m line 330. dpkg: error processing package linux-image-4.10.0-37-generic (--remove): installed linux-image-4.10.0-37-generic package post-removal script subprocess returned error e xit status 1 dpkg: too many errors, stopping Errors were encountered while processing: linux-image-4.10.0-37-generic Processing was halted because there were too many errors. E: Sub-process /usr/bin/dpkg returned an error code (1) marco@marco-ThinkPad:
Mordoc
  • 2,074
M.Hoppe
the same for
/etc/grub.d/10_linux_proxy and /etc/grub.d/31_linux_proxy these will remove exexutable flag from the skripts. Then we have a folder created with the same date.
@M.Hoppe I'm sorry, I oversaw one file. sudo chmod -x /etc/grub.d/34_os-prober_proxy
and why in havens name is an bin and backup folder there?
and
So it will not disturb.
Make sure that you have enough place and inodes free with
df -h;df-i
you can control it.
good luck the files from year 2017 and I have no idea how much your Paketmanagment is really damaged.
Do not use grub-customizer it makes more work, than the work were to make changes in grub2 manually.
nobody
  • 5,792
