L2TP VPN is not working on newly installed Ubunut 20.04 and 20.10. Credentials are correct and same is working with Ubuntu 18.04
Nitish kumar
  • 61
The package network-manager-l2tp is required.
You may have to install it:
sudo apt install network-manager-l2tp
I hope it helps
I was facing this myself in Ubuntu 20.04 and 21.04, and a simple one-liner solved all requirements necessary for my L2TP/IPsec setup to work properly:
sudo apt install --install-suggests network-manager-l2tp-gnome
This installs all packages mentioned in the previous answers, too. Endpoint to connect to is a Ubiquiti EdgeRouter ERLite-3.
pwntr
  • 31
Check your log i suspect you may need to install these as well if the dependancy is not met:
 sudo apt install libstrongswan-standard-plugins libstrongswan-extra-plugins
ognjen011
  • 1,403
