Cant use my usb stick
I tried using nautilus formatting the usb, I get: "Error formatting volume" I tried using fdisk and even the dd command but nothing works.
If I put the usb in my laptop in windows, after a moment it even disappears from This PC (in ubuntu it does stay visible in nautilus).
There are a few files on my usb, I can't delete them either (I get "You don't have sufficient permissions to delete the file ... ".
What are the options to fix my usb stick?
EDIT: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt. Automatically removing dirty bit. Boot sector contents: ... Then it gives an error that it can't find /dev/sdb so whenever performing some operation on the usb, it will eventually be like windows where you can't see the usb in nautilus anymore.
Minimum size is 41mb??
Details of gdb formatting
This stack is more about problems when writing to USB sticks.
Do not rule out the defective scenario for too long, it will save you a lot of time, maybe...
ingank
  • 121
