Good evening everybody, I'm a beginner on Ubuntu. I almost successfully installed Xubuntu 20.04. I say almost because I'm not able to make my external screen work. It has been difficult to mke it recognised (Nvidia driver 455 was just unable to do it). I downgraded to the driver 450 : screen recognised but black.
Does anyone have a solution ? Don't hesitate if you need more specific hints.
Hope the followings can help :)
Best regards,
Jimmy
j@j-Nitro-AN515-44:~$ lspci -vnn | grep -A12 '\''[030[02]\]' | grep -Ei "vga|3d|display|kernel"
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:1f95] (rev a1) (prog-if 00 [VGA controller])
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
05:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636] (rev c7) (prog-if 00 [VGA controller])
Kernel driver in use: amdgpu
Kernel modules: amdgpu
j@j-Nitro-AN515-44:~$ uname -a
Linux s-Nitro-AN515-44 5.8.0-33-generic #36~20.04.1-Ubuntu SMP Wed Dec 9 17:01:13 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
j@j-Nitro-AN515-44:~$ xrandr
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.01+
1680x1050 60.01
1280x1024 60.01
1440x900 60.01
1280x800 60.01
1280x720 60.01
1024x768 60.01
800x600 60.01
640x480 60.01
HDMI-1-0 connected 1920x1080+1920+0 531mm x 299mm
1920x1080 60.00+
1680x1050 59.95
1440x900 74.98 59.89
1280x1024 75.02 60.02
1280x720 60.00
1024x768 75.03 60.00
800x600 75.00 60.32
640x480 75.00 72.81 59.94
j@j-Nitro-AN515-44:~$ dpkg -l | grep -v ^ii
Souhait=inconnU/Installé/suppRimé/Purgé/H=à garder
| État=Non/Installé/fichier-Config/dépaqUeté/échec-conFig/H=semi-installé/W=attend-traitement-déclenchements
|/ Err?=(aucune)/besoin Réinstallation (État,Err: majuscule=mauvais)
||/ Nom Version Architecture Description
rc libnvidia-compute-455:amd64 455.38-0ubuntu0.20.04.1 amd64 NVIDIA libcompute package
rc libpython2.7-minimal:amd64 2.7.18-1~20.04 amd64 Minimal subset of the Python language (version 2.7)
rc linux-image-5.4.0-42-generic 5.4.0-42.46 amd64 Signed kernel image generic
rc linux-image-5.4.0-54-generic 5.4.0-54.60 amd64 Signed kernel image generic
rc linux-modules-5.4.0-42-generic 5.4.0-42.46 amd64 Linux kernel extra modules for version 5.4.0 on 64 bit x86 SMP
rc linux-modules-5.4.0-54-generic 5.4.0-54.60 amd64 Linux kernel extra modules for version 5.4.0 on 64 bit x86 SMP
rc linux-modules-extra-5.4.0-42-generic 5.4.0-42.46 amd64 Linux kernel extra modules for version 5.4.0 on 64 bit x86 SMP
rc linux-modules-extra-5.4.0-54-generic 5.4.0-54.60 amd64 Linux kernel extra modules for version 5.4.0 on 64 bit x86 SMP
rc linux-modules-nvidia-455-5.4.0-54-generic 5.4.0-54.60 amd64 Linux kernel nvidia modules for version 5.4.0-54
rc nvidia-compute-utils-455 455.38-0ubuntu0.20.04.1 amd64 NVIDIA compute utilities
rc nvidia-dkms-455 455.38-0ubuntu0.20.04.1 amd64 NVIDIA DKMS package
rc nvidia-kernel-common-455 455.38-0ubuntu0.20.04.1 amd64 Shared files used with the kernel module
rc python2.7-minimal 2.7.18-1~20.04 amd64 Minimal subset of the Python language (version 2.7)
j@j-Nitro-AN515-44:~$ dpkg -l | grep nvidia
ii libnvidia-cfg1-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-450 450.80.02-0ubuntu0.20.04.2 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA libcompute package
ii libnvidia-compute-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA libcompute package
ii libnvidia-decode-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ifr1-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii linux-modules-nvidia-455-5.4.0-58-generic 5.4.0-58.64 amd64 Linux kernel nvidia modules for version 5.4.0-58
ii nvidia-compute-utils-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA compute utilities
ii nvidia-dkms-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA DKMS package
ii nvidia-driver-430 440.100-0ubuntu0.20.04.1 amd64 Transitional package for nvidia-driver-440
ii nvidia-driver-440 450.80.02-0ubuntu0.20.04.2 amd64 Transitional package for nvidia-driver-450
ii nvidia-driver-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-450 450.80.02-0ubuntu0.20.04.2 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.14 all Tools to enable NVIDIA's Prime
ii nvidia-settings 440.82-0ubuntu0.20.04.1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA binary Xorg driver
config : Acer Nitro 5 AN515-44 | Xubuntu 20.04 | XFCE 4.14 | Kernel 5.8.0-33 | AMD Ryzen 5 4600H | 8 Go | GTX 1650 TI (4 Go), AMD Radeon Vega 6 et Optimus
