I installed xrdp and already it was not working out of the box. I had to apply following two fixes. Fix 1, used the answer by Nemo and fix 2, used the answer by DeepSpace101.
Now I get to problem 3. Namely I want to start Clion from the console using nohup clion & and I get following error: Cannot find VM options file I know that this is a problem related to xrdp, because locally this command works. While we're at it, I also don't have a dashboard or the favorites bar on the left. How can I get xrdp to work(clion issue) and to look(dashboard, favorites bar) like when I log locally into Ubuntu 20.04?
- 386
@Hakaishin
To solve your Desktop look'n feel while connected through xRDP
xRDP can be used in conjunction with Ubuntu (Gnome Desktop) and present you the same Desktop look'n feel but you have to perform some post configuration actions if you have installed xrdp manually
To have the Ubuntu gnome desktop with dock bar presented to you, you can
Option 1 - Manual Fix
Try to create and populate the file ~/.xsessionrc with the following content
export GNOME_SHELL_SESSION_MODE=ubuntu
export XDG_CURRENT_DESKTOP=ubuntu:GNOME
export XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg
Please note that the .xsessionrc file is a hidden file (located in your home directory)
This would be for a single user. If multiple users need to perform remote connection, each user would need to have this file created in their profile
Option 2 - Automated install
You can also use the xrdp-installer script that basically perform the installation of the software and perform some post configuration actions that would provide you the same look'n feel when remotely connected as the one you have when connected to local console
the script (current version is 1.2.1) and how to use it can be found here
Please always check for the latest version of the script at this location
Hope this help
Till next time
See ya
- 2,778
