after installing xserver-xorg-video-dummy with the command
sudo apt install -y xserver-xorg-video-dummy
paste the high res configuration into the file 20-dummy.conf
sudo cat > /usr/share/X11/xorg.conf.d/20-dummy.conf
following content:
Section "Device"
Identifier "DummyDevice"
Driver "dummy"
VideoRam 1024000
EndSection
Section "Screen"
Identifier "DummyScreen"
Device "DummyDevice"
Monitor "DummyMonitor"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "2560x1440_60.0"
EndSubSection
EndSection
Section "Monitor"
Identifier "DummyMonitor"
HorizSync 30-200
VertRefresh 50-1000
Modeline "2560x1440_60.00" 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync
EndSection
if you need another resolution, call the calculate VESA CVT mode lines:
cvt 2048 1440
then copy over cvt 2048 1440 generated string into the 20-dummy.conf file
# 2048x1440 59.97 Hz (CVT) hsync: 89.53 kHz; pclk: 249.25 MHz
Modeline "2048x1440_60.00" 249.25 2048 2200 2416 2784 1440 1443 1453 1493 -hsync +vsync
update the same resolution mode name "2048x1440_60.00" in the SubSection "Display"
and reboot
